1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Help in debugging ACF connection issue
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: "Hu, Yong" <yhu at bnl.gov>, Érico Nogueira Rolim <erico.rolim at lnls.br>
Cc: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Fri, 6 Mar 2026 15:51:04 -0600
Hi Yong,
On 3/6/26 2:59 PM, Hu, Yong wrote:
3.  Manually start the first softIOC 'bpm-fron':  it has an ACF which reads a PV (myCommand:just4TestACF) that is provided by the second softIOC 'bpm-rear' .
Could you also add a record with a CA link to "myCommand:just4TestACF"?
I would be interested to know if you have a situation where dbCa can connect, but asCa can not.
also, with https ://github.com/mdavidsaver/cashark the "tshark" CLI can give more meaningful output than "tcpdump".
Conclusion: just as I mentioned below, most likely your IOCs start before your server's network is fully functional (valid IP address).
To CA developers: Is this a feature or a bug in the Access security Channel Access (asCa)?
This may be related to the behavior of EPICS_CA_AUTO_ADDR_LIST=YES, which is evaluated once at startup using the list of interfaces configured at that time.
Re: Help in debugging ACF connection issue Hu, Yong via Tech-talk
Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
Re: Help in debugging ACF connection issue Michael Davidsaver via Tech-talk
Re: Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
Prev: Re: pvxput denied via EPICS_PVA_NAME_SERVERS but works via EPICS_PVA_ADDR_LIST --- (pvxs 1.5.1 / p4p 4.1.7) Michael Davidsaver via Tech-talk
Next: Re: pvxput denied via EPICS_PVA_NAME_SERVERS but works via EPICS_PVA_ADDR_LIST --- (pvxs 1.5.1 / p4p 4.1.7) Williams Jr., Ernest L. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Help in debugging ACF connection issue Hu, Yong via Tech-talk
Next: Re: Help in debugging ACF connection issue Hu, Yong via Tech-talk
