1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Help in debugging ACF connection issue
From: "Hu, Yong via Tech-talk" <tech-talk at aps.anl.gov>
To: Érico Nogueira Rolim <erico.rolim at lnls.br>, Michael Davidsaver <mdavidsaver at gmail.com>
Cc: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Thu, 5 Mar 2026 17:47:04 +0000
Hi Érico,
Thanks for sharing this interesting subtle CA connection issue.
Another thing worthy of checking: If you use systemd, make both IOC services start after network-online.target, to avoid your IOCs start before your NICs/IPs are fully functional.
I always think CA clients will continuously attempt to connect until timeout (EPICS_CA_MAX_SEARCH_PERIOD, 300-second). I am surprised it never connects in your asCa case.
Cheers,
Yong
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Érico Nogueira Rolim via Tech-talk <tech-talk at aps.anl.gov>
Date: Tuesday, February 24, 2026 at 1:14 PM
On 2/24/26 07:02, Michael Davidsaver wrote:
On 2/23/26 3:36 PM, Érico Nogueira Rolim via Tech-talk wrote:
Hi, all! We have had some occasional issues when rebooting servers in our BPM infrastructure, and I'd like to request guidance on how to best debug it. We have an IOC for each RF front-end and an IOC for the actual BPM board, and we have an Access Security rule to block writes to certain front-end PVs when the fast orbit distortion detection is enabled in the BPM board.
Sometimes, when these servers are rebooted, the front-end IOC is unable to connect to the PV from the BPM board IOC
So it never connects at all?  Odd.
Indeed. We rarely need to write to these PVs, so we can go without noticing these issues for months, and it doesn't connect for that whole time.
... While writing this email, I thought of adding a proxy record in the front-end DB that connects to the outside PV, and checking the connection on that. Should it yield different results? Is the connection path considerably different between DB links and AS links?
This seems an interesting test.  The asCa code [1] creates a separate CA client context to what the dbCa code (aka. CA_LINK) uses [2].  Both should use the same configuration from the environment, and so should yield the same result.
https ://github.com/epics-base/epics-base/blob/3855356d2faef8ccf67ae5d0a368d44ef2527a5c/modules/database/src/ioc/as/asCa.c#L172-L173
https ://github.com/epics-base/epics-base/blob/3855356d2faef8ccf67ae5d0a368d44ef2527a5c/modules/database/src/ioc/db/dbCa.c#L1108-L1109
I will make a patch for this and deploy it when possible, then. I'll report back when I have results!
Re: Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
Re: Help in debugging ACF connection issue Hu, Yong via Tech-talk
Re: Help in debugging ACF connection issue Michael Davidsaver via Tech-talk
Prev: Re: ADAndor IOC Restart Issue: Camera Handle Already Claimed After Ctrl+X Termination Hu, Yong via Tech-talk
Next: Re: ADAndor IOC Restart Issue: Camera Handle Already Claimed After Ctrl+X Termination Henrique F. Simoes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Help in debugging ACF connection issue Michael Davidsaver via Tech-talk
Next: Re: Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
