Hi Yong!
On 3/5/26 14:47, Hu, Yong wrote:
Hi Érico,
Thanks for sharing this interesting subtle CA connection issue.
Another thing worthy of checking: If you use systemd, make both IOC services start after
network-online.target, to avoid your IOCs start before your NICs/IPs are fully functional.
Should this still matter for IOCs on the same server, since they can send broadcasts on the loopback interface? I even checked the listening sockets opened by each IOC, and they are all opened with 0.0.0.0, so specific network devices shouldn't matter...
Still, it might be worth a try.
I always think CA clients will continuously attempt to connect until timeout (EPICS_CA_MAX_SEARCH_PERIOD, 300-second). I am surprised it never connects in your
asCa case.
As am I!
Cheers,
Yong
On 2/24/26 07:02, Michael Davidsaver wrote:
On 2/23/26 3:36 PM, Érico Nogueira Rolim via Tech-talk wrote:
Hi, all!
We have had some occasional issues when rebooting servers in our BPM
infrastructure, and I'd like to request guidance on how to best debug it.
We have an IOC for each RF front-end and an IOC for the actual BPM
board, and we have an Access Security rule to block writes to certain
front-end PVs when the fast orbit distortion detection is enabled in the
BPM board.
Sometimes, when these servers are rebooted, the front-end IOC
is unable to connect to the PV from the BPM board IOC
So it never connects at all? Odd.
Indeed. We rarely need to write to these PVs, so we can go without noticing these issues for months, and it doesn't connect for that whole time.
While writing this email, I thought of adding a proxy record in the
front-end DB that connects to the outside PV, and checking the
connection on that. Should it yield different results? Is the connection
path considerably different between DB links and AS links?
This seems an interesting test. The asCa code [1] creates a separate CA client context to what the dbCa code (aka. CA_LINK) uses [2]. Both should use the same configuration from the environment,
and so should yield the same result.
https ://github.com/epics-base/epics-base/blob/3855356d2faef8ccf67ae5d0a368d44ef2527a5c/modules/database/src/ioc/as/asCa.c#L172-L173
https ://github.com/epics-base/epics-base/blob/3855356d2faef8ccf67ae5d0a368d44ef2527a5c/modules/database/src/ioc/db/dbCa.c#L1108-L1109
I will make a patch for this and deploy it when possible, then. I'll report back when I have results!
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta
ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying
to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
- Re: Help in debugging ACF connection issue Ralph Lange via Tech-talk
- Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
- Re: Help in debugging ACF connection issue Michael Davidsaver via Tech-talk
- Re: Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
- Re: Help in debugging ACF connection issue Hu, Yong via Tech-talk
Propagating Frontend-Authenticated User Identity to EPICS CA/PVA Clients André Favoto via Tech-talk
Re: Compressed image without NDPluginCodec Érico Nogueira Rolim via Tech-talk
2025
<2026>
2025
<2026>
