1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Help in debugging ACF connection issue
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Fri, 6 Mar 2026 16:52:41 +0100
On Fri, 6 Mar 2026 at 13:51, Érico Nogueira Rolim via Tech-talk <tech-talk at aps.anl.gov> wrote:
On 3/5/26 14:47, Hu, Yong wrote:
Another thing worthy of checking: If you use systemd, make both IOC services start after network-online.target, to avoid your IOCs start before your NICs/IPs are fully functional.
Should this still matter for IOCs on the same server, since they can send broadcasts on the loopback interface? I even checked the listening sockets opened by each IOC, and they are all opened with 0.0.0.0, so specific network devices shouldn't matter... Still, it might be worth a try.
Keep in mind that CA does not use localhost/loopback by default. (Else the client would always get two replies for a local IOC on a machine with a NIC.) You need to configure CA to use localhost.
I always think CA clients will continuously attempt to connect until timeout (EPICS_CA_MAX_SEARCH_PERIOD, 300-second). I am surprised it never connects in your asCa case.
As am I!
That value is - as the name implies -  a maximum search period and *not* a timeout.
CA clients will continuously attempt to connect in increasing intervals. These intervals will increase up to that value.
Cheers,
~Ralph
Re: Help in debugging ACF connection issue Hu, Yong via Tech-talk
Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
Re: Help in debugging ACF connection issue Michael Davidsaver via Tech-talk
Re: Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
Prev: Re: Compressed image without NDPluginCodec Sukhanov, Andrei via Tech-talk
Next: pvxput denied via EPICS_PVA_NAME_SERVERS but works via EPICS_PVA_ADDR_LIST --- (pvxs 1.5.1 / p4p 4.1.7) Williams Jr., Ernest L. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
Next: Re: Help in debugging ACF connection issue Hu, Yong via Tech-talk
