1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Latest ADPilatus version for camserver 7.3.13
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech-Talk <tech-talk at aps.anl.gov>, "Henrique F. Simoes" <henrique.simoes at lnls.br>
Cc: Guilherme Rodrigues de Lima <guilherme.lima at lnls.br>
Date: Mon, 9 Mar 2026 16:20:34 +0000
We are using camserver from tvx-7.3.13-121212f/ on some old Pilatus 100K detectors.  We use the latest version of ADPilatus (R2-9) and it works fine.  ADPilatus should not care what version of camserver you are using.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Henrique F. Simoes via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, March 9, 2026 9:02 AM
Subject: Latest ADPilatus version for camserver 7.3.13
Hi, folks.
We have a few ancient Pilatus2 detectors at Sirius, running with
camserver 7.2.70 (Pilatus 300K) and 7.3.13 (Pilatus 100K and 2M).
Historically, we have used ADPilatus R2-1, but we recently revisited the
deployment procedure to run camserver virtualized (with PCI passthrough)
and asked ourselves if there isn't any newer version that still works
fine with such legacy camserver's API.
In the past, someone here tried upgrading to the latest release by that
time, and it supposedly didn't work. I don't know any details about
this, but it makes me wonder if there is any actual break in
compatibility.
Giving a quick look at the release notes, I didn't find any explicit
mention of which ADPilatus versions break backward compatibility. I
assume R2-2 would still be fine to be used with camserver 7.3.13, as it
is explicitly mentioned in the corresponding release notes, but anything
newer than that depends on how the backward compatibility was designed
in the driver.
Which ADPilatus version is the latest one that still supports,
respectively, camserver 7.2.70 and 7.3.13?
(Hopefully, we can upgrade Pilatus 300K to run 7.3.13 as well, but I'm
not sure yet.)
Henrique F. Simões
Control Software Group (SwC)
Brazilian Synchrotron Light Laboratory (LNLS)
Brazilian Center for Research in Energy and Materials (CNPEM)
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Latest ADPilatus version for camserver 7.3.13 Henrique F. Simoes via Tech-talk
Prev: RE: Help in debugging ACF connection issue Stephen Dann - STFC UKRI via Tech-talk
Next: Re: Latest ADPilatus version for camserver 7.3.13 Henrique F. Simoes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Latest ADPilatus version for camserver 7.3.13 Henrique F. Simoes via Tech-talk
