1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: RE: Help in debugging ACF connection issue
From: Stephen Dann - STFC UKRI via Tech-talk <tech-talk at aps.anl.gov>
To: Érico Nogueira Rolim <erico.rolim at lnls.br>, "Hu, Yong" <yhu at bnl.gov>
Cc: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Mon, 9 Mar 2026 16:01:19 +0000
Hi Érico,
Try “After=network-online.target” and “Wants=network-online.target” instead. That’s what I’ve used in the past. “After=network.target” doesn’t do much, according to the docs (man systemd.special).
Stephen
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Érico Nogueira Rolim via Tech-talk
Sent: 09 March 2026 14:54
To: Hu, Yong <yhu at bnl.gov>
Subject: Re: Help in debugging ACF connection issue
Hi Yong!
Thank you very much for the thorough investigation of our issue, and even managing to reproduce it! I greatly appreciate it.
We are indeed using systemd, so I will try to use the After=network.target directive first. I hope to be able to test this tomorrow, so I will let you know about the results then.
Cheers,
Érico
PS: I noticed that the systemd-softioc repository has been archived. Are you using something else now?
On 3/6/26 20:02, Hu, Yong wrote:
You don't often get email from yhu at bnl.gov. Learn why this is important
Hi Michael,
I did the whole test again after adding a CA link to "myCommand:just4TestACF" in my first softIOC. Both dbCa and asCa cannot connect if my network is turned off at the beginning.
You mentioned that EPICS_CA_AUTO_ADDR_LIST (and EPICS_CA_ADDR_LIST) is evaluated once at startup. That is a very point. So, I did one more test by setting EPICS_CA_ADDR_LIST to a broadcast IP, i.e. 192.168.12.255 (EPICS_CA_AUTO_ADDR_LIST seems Okay with either YES or NO)
$ softIoc -d test.db -a default.acf
asSetFilename: Warning - relative paths won't usually work
Starting iocInit
## EPICS R7.0.5
## Rev. 2021-05-13T07:10-0400
CAC: error = "Network is unreachable" sending UDP msg to 192.168.12.255:5064
Warning: RSRV has empty beacon address list
epics> epicsParamShow
EPICS_CA_ADDR_LIST: 192.168.12.255
EPICS_CA_CONN_TMO: 30.0
EPICS_CA_AUTO_ADDR_LIST: YES
Now, both dbCa and asCa automatically connect once my network is turned on.
epics> ascar
1 channels 0 not connected
epics> dbcar
CA links in all records
Total 4 CA links; 4 connected, 0 not connected.
    0 can't read, 0 can't write.  (0 disconnects, 0 writes prohibited)
epics> casr 1
Channel Access Server V4.13
1 client connected:
    TCP client at 192.168.12.44:61165 'wps-168932.lan':
      User 'yonghu', V4.13, Priority = 0, 1 Channel
CAS-TCP server on 0.0.0.0:5064 with
    CAS-UDP name server on 0.0.0.0:5064
Sending CAS-beacons to 0 addresses:
Érico, you have two ways to fix the ACF connection issue: add EPICS_CA_ADDR_LIST to your IOC's environment variable; OR make sure your network is ready before your IOCs start up.
Cheers,
Yong
From: Michael Davidsaver <mdavidsaver at gmail.com>
Date: Friday, March 6, 2026 at 4:51
 PM
Hi Yong,
On 3/6/26 2:59 PM, Hu, Yong wrote:
3.  Manually start the first softIOC 'bpm-fron':  it has an ACF which reads a PV (myCommand:just4TestACF) that is provided by the second softIOC 'bpm-rear' .
Could you also add a record with a CA link to "myCommand:just4TestACF"?
I would be interested to know if you have a situation where dbCa can connect, but asCa can not.
also, with https ://github.com/mdavidsaver/cashark the "tshark" CLI can give more meaningful output than "tcpdump".
Conclusion: just as I mentioned below, most likely your IOCs start before your server's network is fully functional (valid IP address).
To CA developers: Is this a feature or a bug in the Access security Channel Access (asCa)?
This may be related to the behavior of EPICS_CA_AUTO_ADDR_LIST=YES, which is evaluated once at startup using the list of interfaces configured at that time.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
Re: Help in debugging ACF connection issue Michael Davidsaver via Tech-talk
Re: Help in debugging ACF connection issue Hu, Yong via Tech-talk
Prev: Re: MAXnet Alarm State Under High Motor Command Load Jiajun Tian via Tech-talk
Next: Re: Latest ADPilatus version for camserver 7.3.13 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
Next: Re: Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
ANJ, 13 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
