1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: AW: pvget, pvxget and pvxs interoperability and differences
From: "Gotz, Malte via Tech-talk" <tech-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 12 Mar 2026 10:20:39 +0000
Hello Michael,
thank you for your quick reply. I totally understand that pv… and pvx… are not fully compatible and you do give ample warning, that the command line tools from pvxs are rather for testing. I mostly remarked on the discrepancies, because I also couldn’t find a definitive documentation on how to use that feature. Now, I know, this wasn’t just a failure of my search skills.
As far as I understand it this explains the differences in some -r arguments working for pvxget but not for pvget and vice versa.
The more pressing issue for me is, that if I create an NT/Table group with QSRV2, I can’t retrieve a single column using pvget with any syntax. My understanding is that the client tool (pvget) should parse the string into some structure and send that via PVA to retrieve/request the data. The QSRV2 on the other hand doesn’t need to parse the string I give with pvget -r, right?
So, any idea what is going on here?
Von: Michael Davidsaver <mdavidsaver at gmail.com>
Gesendet: Mittwoch, 11.
März 2026 21:48
An: Gotz, Malte <malte.gotz at helmholtz-berlin.de>
Cc: tech-talk at aps.anl.gov
Betreff: Re: pvget, pvxget and pvxs interoperability and differences
On 3/11/26 7:53 AM, Michael Davidsaver wrote:
PRs and issues open.
I have created an additional issue specifically about pvRequest syntax interoperability
https://github.com/epics-base/pvxs/issues/156
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: AW: pvget, pvxget and pvxs interoperability and differences Peter Milne via Tech-talk
pvget, pvxget and pvxs interoperability and differences Gotz, Malte via Tech-talk
Re: pvget, pvxget and pvxs interoperability and differences Michael Davidsaver via Tech-talk
Prev: Re: ADAndor IOC Restart Issue: Camera Handle Already Claimed After Ctrl+X Termination Kim, Kuktae via Tech-talk
Next: E3 conda build problem Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: pvget, pvxget and pvxs interoperability and differences Michael Davidsaver via Tech-talk
Next: Re: AW: pvget, pvxget and pvxs interoperability and differences Peter Milne via Tech-talk
