"$EPICS_PVA_ADDR_LIST". So what you show below is what I was asking about, and it looks consistent with your CLI session configuration.
Looking back, I forgot to ask which version of PVXS you are running. If it is <= 1.4.0, then I can explain the issue you see as a bug which was fixed in 1.4.1.
Meanwhile I included following lines in my st.cmd file
epicsEnvSet("EPICS_PVAS_INTF_ADDR_LIST","239.128.1.6")
epicsEnvSet("EPICS_PVAS_AUTO_BEACON_ADDR_LIST","NO")
epicsEnvSet("EPICS_PVA_AUTO_ADDR_LIST","NO")
EpicsEnvSet("EPICS_PVAS_BEACON_ADDR_LIST","239.128.1.7,10")
After running the st.cmd file, I ran the
pvxsr command and the output is
epics> pvxsr
EPICS_PVAS_AUTO_BEACON_ADDR_LIST=NO
EPICS_PVAS_BEACON_ADDR_LIST=239.128.1.7:5076,10
EPICS_PVAS_BROADCAST_PORT=5076
EPICS_PVAS_IGNORE_ADDR_LIST=
EPICS_PVAS_INTF_ADDR_LIST=239.128.1.6:5075,-1 0.0.0.0
EPICS_PVAS_SERVER_PORT=42011
Source: __builtin prio=-1
Source: __server prio=-1
Source: acnet prio=0
Source: qsrvSingle prio=0
Source: qsrvGroup prio=1
And still my subscribed PV is undefined
epics> dbpr PIP2:CTRL_MPS:acq2106_347_follower
AMSG: ASG : DESC: DISA: 0
DISV: 1 NAME: PIP2:CTRL_MPS:acq2106_347_follower
NAMSG: SEVR: INVALID STAT: UDF SVAL: 0
TPRO: 0 VAL : 0
Where
record(longin, "$(acc):$(sys)_$(group):$(XRM-ID)_follower") {
#field(INP, {pva:{pv:"$(acc):$(sys)_$(group):$(XRM-ID)_counter", "proc":"CP"}})
field(INP, {pva:{pv:"acq2106_347:1:AI:WF:17:TH", "proc":"CP"}})
#field(INP, "acq2106_347:1:AI:WF:17:TH CP")
Varuna
[EXTERNAL] – This message is from an external sender
On 3/26/26 9:09 AM, Varuna Crishan Meddage wrote:
Hi Michalel
Following is the output after printing out ENV variables.
It looks to me as if the address list is different between the two cases. I suggest setting the full address list in the IOC environment.
iocdev1$ env | grep EPICS_PVA
EPICS_PVA_ADDR_LIST=239.128.1.6,8@eno1 10.200.21.28 10.200.21.29 10.200.12.73 10.200.16.47 10.200.16.40 10.200.16.58 10.200.16.59
EPICS_PVA_AUTO_ADDR_LIST=NO
EPICS_PVAS_BEACON_ADDR_LIST=239.128.1.7,10
=============================== INSIDE EPICS SESSIION =============================
epics> pvxsr
EPICS_PVAS_SERVER_PORT=40515
On 3/25/26 1:54 PM, Varuna Crishan Meddage wrote:
I created the following PV
record(waveform, "PIP2:CTRL_MPS:acq2106_current")
field(INP, {pva:{pv:"acq2106_347:1:AI:WF:17", "proc":"CPP"}})
field(FTVL, "DOUBLE")
field(NELM, "4096")
field(SCAN, "1 second")
But it complains that input PV is disconnected.
iocdev1$ pvxget acq2106_347:1:AI:WF:17
Is your IOC running with the same PVA configuration (environment variables) as your shell session?
fyi. At the IOC shell, run "pvxsr" to see the effective configuration (after auto address list expansion).
epics>
pvxsr
EPICS_PVAS_BEACON_ADDR_LIST=192.168.1.255 10.127.127.255
EPICS_PVAS_INTF_ADDR_LIST=0.0.0.0
EPICS_PVAS_SERVER_PORT=5075
eg. If I run one instance of softIocPVX with
record(calc, "counter") {
field(CALC, "VAL+1")
And a second with
record(longin, "follower") {
field(INP, {pva:{pv:"counter", "proc":"CP"}})
I see that the "follower" record subscribes to the "counter"
epics>
dbgf follower
DBF_LONG: 59 = 0x3b
epics>
dbgf follower
DBF_LONG: 60 = 0x3c
