1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: StreamDevice error involving PCRE library in Debian Trixie
From: Gerrit Kühn via Tech-talk <tech-talk at aps.anl.gov>
To: "Zimoch, Dirk via Tech-talk" <tech-talk at aps.anl.gov>
Date: Wed, 8 Apr 2026 15:39:59 +0200
Am Wed, 18 Mar 2026 21:42:06 +0000
schrieb "Zimoch, Dirk via Tech-talk" <tech-talk at aps.anl.gov>:
Hello Dirk,
Unfortunately, we cannot get your pcre2 branch to compile, it fails with
-MM -MF StreamEpics.d  ../StreamEpics.cc
dbdExpand.pl: No input files for ../O.Common/stream.dbd
dbdExpand.pl: No input files for ../O.Common/stream-base.dbd
dbdExpand.pl: No input files for ../O.Common/stream-scalcout.dbd
make[2]: *** No rule to make target 'stream.dbd.d', needed by 'build'.  Stop.
make[2]: Leaving directory
'/home/epics/EPICS/epics-support/StreamDevice/src/O.linux-x86_64' make[1]:
*** [/home/epics/EPICS/epics-base/configure/RULES_ARCHS:58:
install.linux-x86_64] Error 2 make[1]: Leaving directory
'/home/epics/EPICS/epics-support/StreamDevice/src' make: ***
[/home/epics/EPICS/epics-base/configure/RULES_DIRS:85: src.install] Error 2
Is there anything obvious we are overlooking? We can get a bit further using
https://github.com/daykin/StreamDevice/commits/pcre2
However, this only compiles up to base tag R7.0.9, but it will fail with
R7.0.10. Is there any recommendation on how to proceed? Is there already an
ETA for "official" pcre2 support in StreamDevice? Alternatively, we might
also fall back to a manually installed pcre3 for the time being.
cu
  Gerrit
> There is a branch on github where I started with pcre-2 support.
> Dirk
> Am 19.03.2026 um 10:25 schrieb Windsor Tanner via Tech-talk
> Hello All,
> My question pertains to getting StreamDevice to build on Debian Trixie, as
> device support for EPICS.
> We're running into the following error related to the discrepancy between
> the "new"  library packaged in Trixie, and the one which StreamDevice
> depends on:
> ../RegexpConverter.cc:31:10: fatal error: pcre.h: No such file or directory
>    31 | #include "pcre.h"
> Does anyone know of a workaround/solution for this, other than perhaps
> resorting to the legacy PCRE library? Is there a configuration setting in
> the  StreamDevice clone that could be changed to point to the location of
> the pcre2.h header in Trixie?
> It seems Debian removed the package (ibpcre3-dev) from Trixie that would
> have been compatible with StreamDevice .
> Thanks in advance,
> Windsor
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: StreamDevice error involving PCRE library in Debian Trixie Zimoch, Dirk via Tech-talk
Re: StreamDevice error involving PCRE library in Debian Trixie Michael Davidsaver via Tech-talk
StreamDevice error involving PCRE library in Debian Trixie Windsor Tanner via Tech-talk
Prev: RE: EPICS Collaboration Meeting Spring 2026 - CEA IRFU Paris-Saclay GAGET Alexis via Tech-talk
Next: Re: StreamDevice error involving PCRE library in Debian Trixie Zimoch, Dirk via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: StreamDevice error involving PCRE library in Debian Trixie Zimoch, Dirk via Tech-talk
ANJ, 10 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
