1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Re: StreamDevice error involving PCRE library in Debian Trixie
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: Gerrit Kühn <gerrit.kuehn at aei.mpg.de>
Cc: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Date: Fri, 10 Apr 2026 15:51:38 -0700
On 4/8/26 6:39 AM, Gerrit Kühn via Tech-talk wrote:
Am Wed, 18 Mar 2026 21:42:06 +0000
schrieb "Zimoch, Dirk via Tech-talk" <tech-talk at aps.anl.gov>:
Hello Dirk,
Unfortunately, we cannot get your pcre2 branch to compile, it fails with
-MM -MF StreamEpics.d  ../StreamEpics.cc
dbdExpand.pl: No input files for ../O.Common/stream.dbd
dbdExpand.pl: No input files for ../O.Common/stream-base.dbd
dbdExpand.pl: No input files for ../O.Common/stream-scalcout.dbd
make[2]: *** No rule to make target 'stream.dbd.d', needed by 'build'.  Stop.
make[2]: Leaving directory
'/home/epics/EPICS/epics-support/StreamDevice/src/O.linux-x86_64' make[1]:
*** [/home/epics/EPICS/epics-base/configure/RULES_ARCHS:58:
install.linux-x86_64] Error 2 make[1]: Leaving directory
'/home/epics/EPICS/epics-support/StreamDevice/src' make: ***
[/home/epics/EPICS/epics-base/configure/RULES_DIRS:85: src.install] Error 2
Is there anything obvious we are overlooking? We can get a bit further using
Some of the recipes in src/Makefile are prefixed with spaces instead of a tab.  :P
https://github.com/paulscherrerinstitute/StreamDevice/pull/108
My branch also includes an ugly hack to select correct header and library names.  With these changes, I can build and link on Debian 13.  I have not tried to run anything.
Re: StreamDevice error involving PCRE library in Debian Trixie Gerrit Kühn via Tech-talk
StreamDevice error involving PCRE library in Debian Trixie Windsor Tanner via Tech-talk
Re: StreamDevice error involving PCRE library in Debian Trixie Zimoch, Dirk via Tech-talk
Prev: Re: StreamDevice error involving PCRE library in Debian Trixie Gerrit Kühn via Tech-talk
Next: Re: RTEMS/MVME2100 OMS58 card does not exist! error Miroslaw Dach via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Next: Re: StreamDevice error involving PCRE library in Debian Trixie Gerrit Kühn via Tech-talk
ANJ, 13 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
