1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: StreamDevice error involving PCRE library in Debian Trixie
From: Gerrit Kühn via Tech-talk <tech-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Date: Mon, 13 Apr 2026 09:01:08 +0200
Am Fri, 10 Apr 2026 15:51:38 -0700
schrieb Michael Davidsaver <mdavidsaver at gmail.com>:
> > Is there anything obvious we are overlooking? We can get a bit further
> > using
> Some of the recipes in src/Makefile are prefixed with spaces instead of a
> tab.  :P
THANK YOU!
This was exactly the "obvious" thing I was expecting... I definitely need to
keep more Gentoo systems around to keep me from getting rusty with these
things. :)
> https://github.com/paulscherrerinstitute/StreamDevice/pull/108
> My branch also includes an ugly hack to select correct header and library
> names.  With these changes, I can build and link on Debian 13.  I have not
> tried to run anything.
This hack did not apply cleanly here, but the locally installed pcre3 got
found and processed without it just fine as far as I can see. Everything
compiles and links cleanly now, actual testing is still a bit in the future
but will hopefully follow soon. Thanks again...
cu
  Gerrit
Attachment: smime.p7s
Description: S/MIME cryptographic signature
StreamDevice error involving PCRE library in Debian Trixie Windsor Tanner via Tech-talk
Re: StreamDevice error involving PCRE library in Debian Trixie Zimoch, Dirk via Tech-talk
Re: StreamDevice error involving PCRE library in Debian Trixie Gerrit Kühn via Tech-talk
Re: StreamDevice error involving PCRE library in Debian Trixie Michael Davidsaver via Tech-talk
Prev: Re: RTEMS/MVME2100 OMS58 card does not exist! error Miroslaw Dach via Tech-talk
Next: Re: Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: StreamDevice error involving PCRE library in Debian Trixie Michael Davidsaver via Tech-talk
Next: Job Opportunity at APS/ANL Controls Shen, Guobao via Tech-talk
ANJ, 13 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
