1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Building latest StreamDevice
From: Gerrit Kühn via Tech-talk <tech-talk at aps.anl.gov>
To: "Dudley, David via Tech-talk" <tech-talk at aps.anl.gov>
Date: Tue, 28 Apr 2026 14:58:43 +0200
Hello David,
I think this is the same issue we saw a couple of weeks ago. Michael found
this to be caused by spaces vs. tabs in the Makefile (see
https://epics.anl.gov/tech-talk/2026/msg00506.php) and has created this fix:
https://github.com/paulscherrerinstitute/StreamDevice/pull/108
This solved the issues on our end (both for pcre2 and pcre3).
HTH
cu
  Gerrit
Am Tue, 28 Apr 2026 12:48:13 +0000
schrieb "Dudley, David via Tech-talk" <tech-talk at aps.anl.gov>:
> I have been fighting getting StreamDevice built for weeks, now.
> When I run a compile, it gives me a list of .dbd files that it says it
> can't find. 'dbdExpand.pl: no input files for
> ../O.Common/stream-scalout.dbd' 'dbdExpand.pl: no input files for
> ../O.Common/stream-base.dbd' 'dbdExpand.pl: no input files for
> ../O.Common/stream.dbd'
> It ends with a "no rule to make target 'stream.dbd.d', needed by 'build'.
> I'm sure this is just a support program I don't have installed on this
> machine, but it worked fine until a month or two ago.
> The configuration RELEASE file seems to reference a file called
> "SUPPORT.$(EPICS_HOST_ARCH".. bit that file doesn't exist anywhere (and it
> looks like it's optional anyway).
> Anyone else having this problem
> Later-
> David
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: Building latest StreamDevice Zimoch, Dirk via Tech-talk
Building latest StreamDevice Dudley, David via Tech-talk
Prev: Building latest StreamDevice Dudley, David via Tech-talk
Next: Re: Building latest StreamDevice Zimoch, Dirk via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 28 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
