1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Building latest StreamDevice
From: "Zimoch, Dirk via Tech-talk" <tech-talk at aps.anl.gov>
To: "gerrit.kuehn at aei.mpg.de" <gerrit.kuehn at aei.mpg.de>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 28 Apr 2026 13:28:18 +0000
I had started to work on pcre2 support a while ago but I was at the
Codeathon/sick/on vacation/at the collaboration meeting (in that order for the
last two month) and had not worked on it for a while. As soon as I have worked
off my other backlog, I will get back to it...
Dirk
On Tue, 2026-04-28 at 14:58 +0200, Gerrit Kühn via Tech-talk wrote:
> Hello David,
> I think this is the same issue we saw a couple of weeks ago. Michael found
> this to be caused by spaces vs. tabs in the Makefile (see
> https://epics.anl.gov/tech-talk/2026/msg00506.php ) and has created this fix:
> https://urldefense.us/v3/__https://github.com/paulscherrerinstitute/StreamDevice/pull/108__;!!G_uCfscf7eWS!acicnWtnKlTg1o0esMZoKrFsQkCbDz0pKPOqIe_BPC-ia9wb__nCb9mzBB32yuQTrFTGDb_mrhS0Ei72S8cfT31zqQ$
> This solved the issues on our end (both for pcre2 and pcre3).
> HTH
> cu
>   Gerrit
> Am Tue, 28 Apr 2026 12:48:13 +0000
> schrieb "Dudley, David via Tech-talk" <tech-talk at aps.anl.gov>:
> > I have been fighting getting StreamDevice built for weeks, now.
> > When I run a compile, it gives me a list of .dbd files that it says it
> > can't find. 'dbdExpand.pl: no input files for
> > ../O.Common/stream-scalout.dbd' 'dbdExpand.pl: no input files for
> > ../O.Common/stream-base.dbd' 'dbdExpand.pl: no input files for
> > ../O.Common/stream.dbd'
> > It ends with a "no rule to make target 'stream.dbd.d', needed by 'build'.
> > I'm sure this is just a support program I don't have installed on this
> > machine, but it worked fine until a month or two ago.
> > The configuration RELEASE file seems to reference a file called
> > "SUPPORT.$(EPICS_HOST_ARCH".. bit that file doesn't exist anywhere (and it
> > looks like it's optional anyway).
> > Anyone else having this problem
> > Later-
> > David
Building latest StreamDevice Dudley, David via Tech-talk
Re: Building latest StreamDevice Gerrit Kühn via Tech-talk
Prev: Re: Building latest StreamDevice Gerrit Kühn via Tech-talk
Next: Re: BO which should switch to 1 whenever processed Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: Understanding alarms, alarm server and notification usage in other facilities Érico Nogueira Rolim via Tech-talk
ANJ, 30 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
