1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: RE: MTS/Instron Load Frame Controller IOCs
From: Tom Willemsen - STFC UKRI via Tech-talk <tech-talk at aps.anl.gov>
To: Jonathan Hai <haic at mcmaster.ca>, EPICS Tech-Talk <tech-talk at aps.anl.gov>
Cc: Jason Wigmore <wigmorej at mcmaster.ca>
Date: Wed, 22 Jul 2026 17:43:23 +0000
We have EPICS support for Instron 8800 load frames in two flavours: NI-GPIB for an older-style controller [1] which is almost certainly no longer manufactured, and via Arby.dll for a newer-style controller [2].
These controllers have a reputation at our facility for being somewhat fickle in terms of communications. The arby.dll approach [2] depends on a 32-bit Windows EPICS IOC with manufacturer software running in the background.
[1] https://github.com/ISISComputingGroup/EPICS-instron
[2] https://github.com/ISISComputingGroup/EPICS-InstronArby
Please get in touch if you need further information.
Tom Willemsen
ISIS Neutron and Muon source
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Jonathan Hai via Tech-talk
Sent: 22 July 2026 17:48
To: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Subject: MTS/Instron Load Frame Controller IOCs
Hi everyone,
Thanks for all your help so far, you’ve been fantastic!
Our facility is looking to implement a universal testing frame at one of our beamports, and we are looking to acquire an MTS or Instron load frame controller to control the motors on the frame. Are you folks aware of any IOCs/support modules that have been written for these controllers?
Suggestions for other kinds of epics-compatible controllers that would work for the purpose of driving these motors are also welcome!
Motor Specs:
Parker RX320E
DC Brushed Servo-electric motors
Permanent Current: 7.8A
Supply Voltage: 54V
Peak Current: 20A
Maximum Speed: 3000rpm
Jonathan Hai
Research Engineer/Tech Monkey
Canadian Neutron Beam Laboratory
McMaster University
Sapere Aude
MTS/Instron Load Frame Controller IOCs Jonathan Hai via Tech-talk
Prev: MTS/Instron Load Frame Controller IOCs Jonathan Hai via Tech-talk
Next: Re: What hardware are you using for TC measurements? Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: Re: MTS/Instron Load Frame Controller IOCs Mark Rivers via Tech-talk
ANJ, 22 Jul 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
