1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: MTS/Instron Load Frame Controller IOCs
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech-Talk <tech-talk at aps.anl.gov>, Jonathan Hai <haic at mcmaster.ca>
Cc: Jason Wigmore <wigmorej at mcmaster.ca>
Date: Wed, 22 Jul 2026 19:55:57 +0000
Hi Jonathan,
We use the Galil DMC-4183 controllers.  For high-current servo motors like the Parkers you list, the 3547 driver option will work.  It works with power supplies up to 80V and can drive brushed servo motors up to 8 A continuous and 15 A peak.  We are using them to drive a number of 3-phase brushless motors.
I just used the Galil online  configuration tool to generate this part number. This is an 8-channel version.  I don't know how many motors you need to drive?
The part number is DMC-4183-BOX8-D3547-D3547.
The list price is $5,130.
The EPICS Galil driver is very mature and full-featured.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Jonathan Hai via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, July 22, 2026 11:48 AM
Subject: MTS/Instron Load Frame Controller IOCs
Hi everyone,
Thanks for all your help so far, you’ve been fantastic!
Our facility is looking to implement a universal testing frame at one of our beamports, and we are looking to acquire an MTS or Instron load frame controller to control the motors on the frame. Are you folks aware of any IOCs/support modules that have been written for these controllers?
Suggestions for other kinds of epics-compatible controllers that would work for the purpose of driving these motors are also welcome!
Motor Specs:
Parker RX320E
DC Brushed Servo-electric motors
Permanent Current: 7.8A
Supply Voltage: 54V
Peak Current: 20A
Maximum Speed: 3000rpm
Jonathan Hai
Research Engineer/Tech Monkey
Canadian Neutron Beam Laboratory
McMaster University
Sapere Aude
MTS/Instron Load Frame Controller IOCs Jonathan Hai via Tech-talk
Prev: Re: What hardware are you using for TC measurements? Shen, Guobao via Tech-talk
Next: Modbus Module issue Luis Alberto De Sousa Moreira via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: RE: MTS/Instron Load Frame Controller IOCs Tom Willemsen - STFC UKRI via Tech-talk
ANJ, 23 Jul 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
