1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Create record name manifest during build
From: Jure Varlec via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Fri, 24 Jul 2026 10:56:15 +0200
On 7/24/26 09:04, Ralph Lange via Tech-talk wrote:
I know you can
    echo "exit" | softIoc ./st-dbl-only.cmd
but that is not really elegant, needs a Linux-ish shell, ...
We are talking build-time here, so you are supposed to have a shell available. If you want a bit more elegance, you can omit the echo and redirect stdin to the script
softIoc < st-dbl-only.cmd
Using input redirection will quit the IOC because stdin is closed when it reaches end of file. You don't even need the exit command at the end.
Best,
Jure
Re: Create record name manifest during build Johnson, Andrew N. via Tech-talk
Create record name manifest during build David Bracey via Tech-talk
Re: Create record name manifest during build Mark Rivers via Tech-talk
Re: Create record name manifest during build Pierrick Hanlet via Tech-talk
Re: Create record name manifest during build David Bracey via Tech-talk
Re: Create record name manifest during build Jure Varlec via Tech-talk
Re: Create record name manifest during build Ralph Lange via Tech-talk
Prev: Re: Modbus Module issue Luis Alberto De Sousa Moreira via Tech-talk
Next: Re: Modbus Module issue Luis Alberto De Sousa Moreira via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Create record name manifest during build Ralph Lange via Tech-talk
Next: Re: Create record name manifest during build Johnson, Andrew N. via Tech-talk
ANJ, 24 Jul 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
