1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Naming bits in an mbbiDirect record
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Sat, 5 Sep 2026 14:48:40 +0200
If I remember correctly, some years ago, there was an idea thrown around at a Codeathon to make the 'info()' structures readable across the network.
That feature would allow you to add any number of string tags to any record, but without record-specific code, without blowing up the field list and without adding to the memory footprint of every instance.
Does anyone remember why that feature was never fully developed?
Cheers,
~Ralph
Re: Naming bits in an mbbiDirect record Sukhanov, Andrei via Tech-talk
Re: Naming bits in an mbbiDirect record Simon Rose via Tech-talk
Naming bits in an mbbiDirect record William Badgett via Tech-talk
Re: Naming bits in an mbbiDirect record Ralph Lange via Tech-talk
Re: Naming bits in an mbbiDirect record André Favoto via Tech-talk
Re: Naming bits in an mbbiDirect record Johnson, Andrew N. via Tech-talk
Prev: Re: Naming bits in an mbbiDirect record André Favoto via Tech-talk
Next: Re: Naming bits in an mbbiDirect record Sukhanov, Andrei via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 07 Sep 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
