Benjamin Franksen wrote:
[Aside: Is this definition in epicsTypes.h:
typedef int epicsInt32;
garanteed to work even on 64 bit systems? AFAIK, int is supposed to be
whatever is the most natural (=fast) signed integral value on the given
architecture. Correct me if I am wrong here.]
There is no standard. The C99 standard only defines minimum sizes for
each of the integer types. In particular a long must be at least 32 bits
but may be more.
Some 64 bit compilers use
int 32 bits
long 64 bits
I think that gnu uses
int 32 bits
long 32 bits
long long 64 bits
Although 3.14 currently has epicsTypes.h in src/libCom/misc, it can
easily be moved to
src/libCom/osi/osi/xxx. Thus there can be architecture dependent
versions. Of course, this will not be a complete solution for 3.14
because very little of the code uses epicsTypes.h. Jeff created
epicsTypes.h, which has the comment: "so far this is sufficient for all
archs we have ported to". Thus it was designed to allow architecture
dependent versions.
For 3.15, code should use epicsTypes.h for anything that can be
architecture dependent or for anything that can is network accessable.
Benjamin,
I may not respond to all of your messages because my mind is not big
enough to think about too many things at the same time. It does not mean
that I don't read and consider them. Also please send them to everyone
included on this message.
In paticular, I am reluctant to get in the C++ discussion. I am so
disappointed with what C++ became and Jeff is so much in favor of using
C++ that it is going to be a major problem for V4.
Let me give an example. You praised templates. My response is "How can
templates be OK if they are build on top of the mess that C++ has
created for classes". Just this comment could generate hours of
discussion.
When I think about all the C++ syntax that MUST be done correctly for
defining interfaces, I wonder if we really want to require mere mortals
to get it all right. Remember that I WANT users to extend what epics
base supports. The bigger the learning curve before users can create and
implement their own interfaces, the less usefull the V4 database will
be. Would asynDriver be easier to learn and extent if it was done in
C++? I don't think so. It has a huge learning cure as it is.
Marty
- Re: EPICS base V4 Benjamin Franksen
- Re: EPICS base V4 Andrew Johnson
- Re: EPICS base V4: iocCore database Marty Kraimer
- Re: EPICS base V4: iocCore database Andrew Johnson
- Re: EPICS base V4: iocCore database: Booleans Benjamin Franksen
RE: EPICS base V4: iocCore database Jeff Hill
<2005>
2025
2026
<2005>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
