Proposal for V4:
Change the way in which records are executed, allowing the database
designer to select which threads perform processing of particular sets
of records.
In V3 we create a thread for each scan period, plus a number of other
threads for callbacks etc. so the thread that a record processes in is
vaguely related to its SCAN and PRIO fields. I propose changing
menuScan so it only contains "Passive", "Event", "I/O Interrupt" and
"Periodic". We add another field which is a double called scanPeriod
which can be set to any period in seconds (this two-field approach is
analagous to "Event" and the old EVNT field). We use a series of
epicsTimerQueues or something similar to cause records to be processed
when the relevent time interval has elapsed since they were last run.
Now instead of having a thread for each period, we change the PRIO field
(whcih is currently only used for Event and I/O Interrupt) into a field
called scanThread. This is a menu field which selects which thread
actually does the record processing (executes the epicsTimerQueue), and
this allows the database designer much more control over the relative
priorities of different parts of the IOC's database.
I suspect this would probably increase the number of threads that
actually get used, but it makes it possible to partition off different
parts of the database so that the highest priority work always gets done
even though there's a frequently processed chain going on in some lower
priority thread. We would not need the callback tasks that currently do
I/O Interrupt processing, because the interrupt can just add the record
into the queue for its regular processing thread.
Note that a record which has scan=Passive should still be executed by
the thread of whichever record processes it (FLNK, PP link), although we
could add another choice ("Triggered") where the record's selected
scanThread gets used. Hmm, that has implications for providing a PV-Get
that can cross a thread boundary, making the Getting record wait for the
other to return the desired value... I haven't thought about this part
properly yet, it has implications for semaphores and deadlocks.
Comments?
- Andrew
Dear God, I didn't think orange went with purple until I saw
the sunset you made last night. That was really cool. - Caro
- Re: EPICS base V4 Benjamin Franksen
- Re: EPICS base V4 Ralph Lange
- Re: EPICS base V4: iocCore database Marty Kraimer
- Re: EPICS base V4: iocCore database Andrew Johnson
- Re: EPICS base V4: iocCore database: Booleans Benjamin Franksen
- EPICS base V4 Marty Kraimer
Re: [Fwd: RE: EPICS base V4: iocCore database] Benjamin Franksen
<2005>
2025
2026
RE: EPICS base V4 Jeff Hill
<2005>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
