2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS base V4
Cc: Marty Kraimer <[email protected]>, Eric Norum <[email protected]>, Jeff Hill <[email protected]>, Ralph Lange <[email protected]>, Bob Dalesio <[email protected]>, Ned Arnold <[email protected]>, Matej Sekoranja <[email protected]>
Date: Thu, 24 Feb 2005 12:22:43 +0100
On Thursday 24 February 2005 00:52, Andrew Johnson wrote:
> Proposal for V4:
> Change the way in which records are executed, allowing the database
> designer to select which threads perform processing of particular
> sets of records.
General comment: very good idea.
> In V3 we create a thread for each scan period, plus a number of other
> threads for callbacks etc. so the thread that a record processes in
> is vaguely related to its SCAN and PRIO fields.  I propose changing
> menuScan so it only contains "Passive", "Event", "I/O Interrupt" and
> "Periodic".  We add another field which is a double called scanPeriod
> which can be set to any period in seconds (this two-field approach is
> analagous to "Event" and the old EVNT field).
The data type of the new scan specification is quite naturally expressed
as an algebraic data type (=tagged union). In Haskell I would write
data Scan = Passive | Event Int | Interrupt | Periodic Double
In dbd syntax this could look like:
union(scanSpec) {
    choice(scanPassive,"Passive")
    choice(scanEvent,"Event") {
        field(event,octet)
    choice(scanInterrupt,"Interrupt",)
    choice(scanPeriodic,"Periodic") {
        field(rate,float)
(I took the freedom to allow leaving out an empty pair of braces "{}".
This makes the union notation compatible with the one for menus, which
are a special case of unions where all choices are tags only without
data.)
One more comment on event scanning. Currently events are specified by a
number between 0 and 255. This has many obvious disadvantages. I think
for V4 we should consider supporting event identification by name,
rather than number. The above would then become
union(scanSpec) {
        field(event,string)
Ben
EPICS base V4 Marty Kraimer
Re: EPICS base V4 Andrew Johnson
Prev: Re: EPICS base V4 Andrew Johnson
Next: memory management Jeff Hill
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS base V4 Ralph Lange
