2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: C strict aliasing rules
To: Kay-Uwe Kasemir <[email protected]>
Cc: Core talk list <[email protected]>
Date: Tue, 28 Nov 2006 10:23:44 -0500
Kay-Uwe Kasemir wrote:
Hi:
Do I understand correctly that the most likely impact for EPICS might be this type of code:
struct xyz_regs
    Word control;
    Word status;
void xyz_operate(char *vme_base)
    struct xyz_regs *xyz = (struct xyz_regs *) vme_base;
    xyz->control = 0x1234;
    if (xyz->status & 0x8000)
The mapping of C structures to hardware registers?
volatile should be used for all access to hardware registers.
volatile prevents compiler optimization.
In that case, the compiler optimization of aliased pointers
isn't the only problem. There's also the structure padding,
memory alignment, and byte order that causes portability issues.
Isn't that best handled by performing register access
via routines like the vxWorks sysInByte(), sysInWord(), sysInLong(), sysPciInLong(), ... ?
-Kay
Re: C strict aliasing rules Eric Norum
Re: C strict aliasing rules Benjamin Franksen
Re: C strict aliasing rules Kay-Uwe Kasemir
Prev: Re: C strict aliasing rules Kay-Uwe Kasemir
Next: Re: C strict aliasing rules Eric Norum
Index: 2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
