On Nov 28, 2006, at 9:23 AM, Marty Kraimer wrote:
Kay-Uwe Kasemir wrote:
Hi:
Do I understand correctly that the most likely impact for EPICS
might be this type of code:
struct xyz_regs
Word control;
Word status;
void xyz_operate(char *vme_base)
struct xyz_regs *xyz = (struct xyz_regs *) vme_base;
xyz->control = 0x1234;
if (xyz->status & 0x8000)
The mapping of C structures to hardware registers?
volatile should be used for all access to hardware registers.
volatile prevents compiler optimization.
Let's not get off on a tangent here. The problem Kay was describing
was one of structure padding, alignment, endianness when using a
structure to define the layout of hardware registers.
The issue on the table is that of compilers imposing their strict
aliasing rules, and what to do about that.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- Re: C strict aliasing rules Kay-Uwe Kasemir
- C strict aliasing rules Eric Norum
- Re: C strict aliasing rules Benjamin Franksen
- Re: C strict aliasing rules Eric Norum
- Re: C strict aliasing rules Marty Kraimer
<2006>
2025
2026
<2006>
2025
2026
