2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base 3.14.11 Release Timetable
To: [email protected]
Date: Tue, 10 Feb 2009 14:37:28 -0600
Hi Ben,
On Tuesday 10 February 2009 13:46:23 Benjamin Franksen wrote:
> > Yup, we currently only have branches at the 2nd level number (3.13.x,
> > 3.14,x. trunk), although if we needed to we could create a branch for a
> > 3rd-level we could.  By linking patches from the Known Problems page
> > we're making fixes available to people without promising that the result
> > has been tested in the same way that an official release is.
> Hm, that sounds as if one should very carefully consider whether to apply
> such patches.
I would agree that a cure is not always better than the illness, depending how
good your doctor is...
> > The EPICS
> > developers at the APS are too busy to do anything more than that, but if
> > someone else wants to help with the release process we could re-think
> > that.
> It depends. How much & what kind of work is requested? What, in fact, /is/
> the test procedure you observe for testing an official release?
The full release procedure that I try to follow can be found in the
base/documentation directory, or for R3.14.10 it's here:
http://www.aps.anl.gov/epics/base/R3-14/10-docs/ReleaseChecklist.html
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Re: Base 3.14.11 Release Timetable Andrew Johnson
Re: Base 3.14.11 Release Timetable Benjamin Franksen
Prev: Re: Base 3.14.11 Release Timetable Benjamin Franksen
Next: libCom tests results 32 bit compatibility mode on windows vista 64 Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Base 3.14.11 Release Timetable Jeff Hill
