2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: libCom tests results 32 bit compatibility mode on windows vista 64
To: <[email protected]>
Date: Wed, 11 Feb 2009 09:34:24 -0700
All,
Here are the libCom test results running in 32 bit compatibility mode on windows vista 64.
Jeff
perl -MTest::Harness -e 'runtests @ARGV if @ARGV;' epicsUnitTestTest.t epicsCal
Test.t epicsAlgorithmTest.t epicsMathTest.t epicsStdioTest.t epicsStringTest.t
picsTimeTest.t epicsThreadTest.t epicsThreadPriorityTest.t epicsThreadPrivateTe
t.t epicsExitTest.t epicsTimerTest.t ringPointerTest.t ringBytesTest.t epicsEve
tTest.t epicsMutexTest.t epicsExceptionTest.t epicsMessageQueueTest.t macEnvExp
ndTest.t macLibTest.t taskwdTest.t blockingSockTest.t
epicsUnitTestTest............1/1 # Test 1 got: "1..11\r\nok  1 - testOk(1)\r\nn
t ok  2 - testOk(0)\r\nok  3 - testPass()\r\nnot ok  4 - testFail()\r\nok  5 #
KIP Skipping two\r\nok  6 # SKIP Skipping two\r\nok  7 - Todo pass # TODO Testi
g Todo\r\nnot ok  8 - Todo fail # TODO Testing Todo\r\nok  9 # SKIP Todo skip\r
nok 10 - testOk1_success\r\nnot ok 11 - testOk1_failure\r\n# Diagnostic\r\n" (e
icsUnitTestTest.t at line 29)
#   Expected: "1..11\nok  1 - testOk(1)\nnot ok  2 - testOk(0)\nok  3 - testPas
()\nnot ok  4 - testFail()\nok  5 # SKIP Skipping two\nok  6 # SKIP Skipping tw
\nok  7 - Todo pass # TODO Testing Todo\nnot ok  8 - Todo fail # TODO Testing T
do\nok  9 # SKIP Todo skip\nok 10 - testOk1_success\nnot ok 11 - testOk1_failur
\n# Diagnostic\n"
#     (Install the Algorithm::Diff module to have differences in multiline
#      output explained.  You might also set the PERL_TEST_DIFF environment
#      variable to run a diff program on the output.)
#  epicsUnitTestTest.t line 29 is: ok($result, $expected); # test output matche
epicsUnitTestTest............ Failed 1/1 subtests
epicsCalcTest................ok
epicsAlgorithmTest...........ok
epicsMathTest................ok
epicsStdioTest...............ok
epicsStringTest.............. Dubious, test returned 3 (wstat 768, 0x300)
 All 1 subtests passed
epicsTimeTest................ok
epicsThreadTest..............ok
epicsThreadPriorityTest......ok
epicsThreadPrivateTest.......ok
epicsExitTest................ok
epicsTimerTest...............ok
ringPointerTest..............ok
ringBytesTest................ok
epicsEventTest...............ok
epicsMutexTest............... All 19 subtests passed
epicsExceptionTest...........ok
epicsMessageQueueTest........ok
macEnvExpandTest.............macLib: macro FOO is undefined (expanding string $
FOO})
macLib: macro FOO is undefined (expanding string ${FOO,BAR})
macLib: macro FOO is undefined (expanding string ${FOO,BAR=baz})
macLib: macro FOO is undefined (expanding string ${FOO,BAR=$(FOO)})
macLib: macro FOO is undefined (expanding string ${FOO,FOO})
macLib: string ${FOO,FOO=$(FOO)} is recursive (expanding macro FOO)
macLib: macro FOO is undefined (expanding string ${FOO,BAR=baz,FUM})
macLib: macro BAZ is undefined (expanding string ${FOO})
macLib: string ${FOO} is recursive (expanding environment variable FOO)
macLib: string ${FOO,FOO=$(FOO)} is recursive (expanding environment variable F
O)
macLib: string ${FOO=$(FOO)} is recursive (expanding environment variable FOO)
macLib: string ${FOO=$(BAR),BAR=$(FOO)} is recursive (expanding environment var
able FOO)
macEnvExpandTest.............ok
macLibTest...................ok
taskwdTest...................Thread testTask2 (022D2430) suspended
taskwdTest...................ok
blockingSockTest.............ok
Test Summary Report
epicsUnitTestTest.t      (Wstat: 0 Tests: 1 Failed: 1)
  Failed test:  1
epicsStringTest.t        (Wstat: 768 Tests: 1 Failed: 0)
  Non-zero exit status: 3
  Parse errors: No plan found in TAP output
epicsMutexTest.t         (Wstat: 0 Tests: 20 Failed: 1)
  Failed test:  20
  Parse errors: Bad plan.  You planned 19 tests but ran 20.
Files=22, Tests=1559, 420 wallclock secs ( 0.19 usr  0.06 sys +  0.53 cusr  0.9
 csys =  1.70 CPU)
Result: FAIL
Failed 3/22 test programs. 2/1559 subtests failed.
mingw32-make[1]: [runtests] Error 255 (ignored)
Jeff
______________________________________________________
Jeffrey O. Hill           Internet     [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Re: libCom tests results 32 bit compatibility mode on windows vista 64 Andrew Johnson
Prev: Re: Base 3.14.11 Release Timetable Andrew Johnson
Next: Re: libCom tests results 32 bit compatibility mode on windows vista 64 Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
