Subject: |
Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 24 Jun 2010 10:15:36 -0500 |
On Thursday 24 June 2010 08:31:54 Ralph Lange wrote:
> Hi Nick,
> On Thu 24 Jun 2010 4:54:51 wrote:
> > I don't think that acctst is a valid epics test harness. I suggest we
> > also look at turning it into one so that it is run with make runtests
> > (and also with our automated test system). Is this a sensible idea?
> Definitely.
Hear, hear!
> Even more definitely it's not an easy task, as acctst involves things
> like pulling and reinserting the network plug in the IOC to check tcp
> circuit timeout/cleanup etc..., stuff that is not easily automated.
.. and note that pulling the network plug is *not* the same as killing the IOC
process on Linux, since the latter results in the OS cleaning up the socket
for you whereas pulling the plug means that all packets stop. It might be
possible to suspend the process to simulate it, but I'd want someone to
compare a couple of network traces to make sure it behaves exactly the same
way.
> Don't want to discourage you, just .... it's going to be fun :-)
Definitely, but well worth-while. I'm guessing that you may not be able to
automate everything, but it probably makes sense to split acctst into multiple
test programs and have the one(s) that need manual intervention not run by the
runtests rule. I would also suggest you create a src/ca/test directory and
put the new test programs in there (note that like libCom/test and db/test
this collection would be built after most of the other src/* directories, see
src/Makefile to see how we arrange that, this allows the tests to use code
that gets built after src/ca if they need it).
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Ralph Lange
- RE: [Merge] lp:~michael-abbott/epics-base/dynamic-array intolp:epics-base nick.rees
- [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Michael Abbott
- Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array intolp:epics-base Ralph Lange
<2010>
2025
2026
<2010>
2025
2026
