Well, part of our test setup is an Ethernet power switch. Is power
cycling OK? Another alternative might be to have a managed switch and
kill it there.
Nick Rees
Principal Software Engineer Phone: +44 (0)1235-778430
Diamond Light Source Fax: +44 (0)1235-446713
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Andrew Johnson
> Sent: 24 June 2010 16:16
> To: [email protected]
> Subject: Re: [Merge]
> lp:~michael-abbott/epics-base/dynamic-array intolp:epics-base
> On Thursday 24 June 2010 08:31:54 Ralph Lange wrote:
> > Hi Nick,
> > On Thu 24 Jun 2010 4:54:51 wrote:
> > > I don't think that acctst is a valid epics test harness.
> I suggest we
> > > also look at turning it into one so that it is run with
> make runtests
> > > (and also with our automated test system). Is this a
> sensible idea?
> > Definitely.
> Hear, hear!
> > Even more definitely it's not an easy task, as acctst
> involves things
> > like pulling and reinserting the network plug in the IOC to
> check tcp
> > circuit timeout/cleanup etc..., stuff that is not easily automated.
> .. and note that pulling the network plug is *not* the same
> as killing the IOC
> process on Linux, since the latter results in the OS cleaning
> up the socket
> for you whereas pulling the plug means that all packets stop.
> It might be
> possible to suspend the process to simulate it, but I'd want
> someone to
> compare a couple of network traces to make sure it behaves
> exactly the same
> way.
> > Don't want to discourage you, just .... it's going to be fun :-)
> Definitely, but well worth-while. I'm guessing that you may
> not be able to
> automate everything, but it probably makes sense to split
> acctst into multiple
> test programs and have the one(s) that need manual
> intervention not run by the
> runtests rule. I would also suggest you create a src/ca/test
> directory and
> put the new test programs in there (note that like
> libCom/test and db/test
> this collection would be built after most of the other src/*
> directories, see
> src/Makefile to see how we arrange that, this allows the
> tests to use code
> that gets built after src/ca if they need it).
> - Andrew
> The best FOSS code is written to be read by other humans --
> Harald Welte
- Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array intolp:epics-base Ralph Lange
- [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Michael Abbott
- RE: [Merge] lp:~michael-abbott/epics-base/dynamic-array intolp:epics-base nick.rees
- Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Andrew Johnson
Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Ralph Lange
<2010>
2025
2026
<2010>
2025
2026
