2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base
To: EPICS Core Talk <[email protected]>
Date: Thu, 24 Jun 2010 11:36:18 -0400
On Thu 24 Jun 2010 11:15:36 Andrew Johnson wrote:
On Thursday 24 June 2010 08:31:54 Ralph Lange wrote:
Even more definitely it's not an easy task, as acctst involves things
like pulling and reinserting the network plug in the IOC to check tcp
circuit timeout/cleanup etc..., stuff that is not easily automated.
.. and note that pulling the network plug is *not* the same as killing the IOC process on Linux, since the latter results in the OS cleaning up the socket for you whereas pulling the plug means that all packets stop. It might be possible to suspend the process to simulate it, but I'd want someone to compare a couple of network traces to make sure it behaves exactly the same way.
For a serious result, acctst hast to be run on a reasonable set of different architecture/OS combinations for client and server. That set should probably include the major host platforms (Linux 32/64bit, Windows, MacOS, Solaris), and a set of different typical target architectures (68k, PPC, ARM) running vxWorks (5 and 6) and RTEMS. If we have a working (at least semi-) automated test suite, we could and should split this over multiple institutes. The more combinations we get covered, the better. There should be an automated way of submitting test results to a central result matrix. I guess there are frameworks around that allow this kind of workflow.
Personally I always pull the plug for VME targets and suspend/continue a softIOC for the Linux target. I'm not sure that the effect is really 100% the same, but at least for acctst it looks similar enough to pass all tests. :-) In a test rack you could power cycle a mini switch to reliably shut down the network.
Ralph
[Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Michael Abbott
RE: [Merge] lp:~michael-abbott/epics-base/dynamic-array intolp:epics-base nick.rees
Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array intolp:epics-base Ralph Lange
Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Andrew Johnson
Prev: Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Andrew Johnson
Next: RE: [Merge] lp:~michael-abbott/epics-base/dynamic-array intolp:epics-base nick.rees
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
