2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 3.15.0.2: Shutdown issues
To: [email protected]
Date: Tue, 18 Nov 2014 15:12:37 -0500
On 11/18/2014 11:37 AM, Michael Davidsaver wrote:
> From a quick look I would guess that at least dbBkptExit(),
> dbLockExit(), and errlogExitHandler() can cause similar problems.  So
> I'll look at making these conditional as well.
Ok, so I think I've backed out enough of the DB cleanup to prevent
crashing due to shutdown races.
I think the remaining atexit hooks for softIoc shouldn't crash.  What is
done is:
> atExit exitDatabase((nil))
For a real IOC (as opposed to a unittest) only doCloseLinks() runs to
cleanup CA_LINK.  For records with extended device support it also
disables "I/O Intr" scans and call del_record().
> atExit ca_client_exit_handler((nil))
Frees a thread local variable.
> atExit dbCaExit((nil))
Stops the CA link worker.
> atExit cacExitHandler((nil))
> atExit twdShutdown((nil))
Stops the watchdog thread.
> atExit errlogExitHandler((nil))
Stops the errlog thread
> atExit ClockTime_Shutdown((nil))
Stops the ClockTimeSync() thread.
None of these should free any global locks so that concurrent operations
using these locks shouldn't operate on free'd memory.
Re: 3.15.0.2: Shutdown issues Benjamin Franksen
3.15.0.2: Shutdown issues Ralph Lange
Re: 3.15.0.2: Shutdown issues Michael Davidsaver
Prev: Re: Jenkins build became unstable: epics-base-3.15 #143 Michael Davidsaver
Next: Re: ringPointerTest Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: 3.15.0.2: Shutdown issues Michael Davidsaver
Next: Re: 3.15.0.2: Shutdown issues Benjamin Franksen
ANJ, 18 Nov 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
