2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem building example application on windows-x64
To: Mark Rivers <[email protected]>, 'Andrew Johnson' <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 27 Dec 2017 18:11:07 -0600
On 12/27/2017 03:15 PM, Mark Rivers wrote:
> epicsSocketDestroy: failed to close a socket because "WINSOCK Error 10093"
> 2017-12-27T14:53:16.250 Receive thread for UDP socket 0.0.0.0:0 has not exited.
Looks like osiSockAttach() isn't being called enough.
It might be useful if you run
> var atExitDebug 1
in the IOC shell and then exit.  This should give some idea of which atexit
handler is making the last osiSockRelease(), and which one should be.
RE: Problem building example application on windows-x64 Mark Rivers
Re: Problem building example application on windows-x64 Andrew Johnson
Prev: Re: Problem building example application on windows-x64 Michael Davidsaver
Next: RE: Problem building example application on windows-x64 Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 28 Dec 2017 · Home · News · About · Talk · Base · Modules · Extensions ·
