2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem building example application on windows-x64
To: 'Michael Davidsaver' <[email protected]>, 'Andrew Johnson' <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 28 Dec 2017 04:50:26 +0000
Hi Michael,
Here is the output you suggested:
epics> var atExitDebug 1
epics> exit
atExit exitDatabase(0000000000000000)
atExit ca_client_exit_handler(0000000000000000)
atExit cacExitHandler(0000000000000000)
atExit twdShutdown(0000000000000000)
atExit syncShutdown(0000000000000000)
atExit dbndShutdown(0000000000000000)
atExit arrShutdown(0000000000000000)
atExit errlogExitHandler(0000000000000000)
atExit &pva_factory_cleanup(0000000000000000)
epicsSocketDestroy: failed to close a socket because "WINSOCK Error 10093"
2017-12-27T22:48:54.048 Receive thread for UDP socket 0.0.0.0:0 has not exited.
> -----Original Message-----
> From: Michael Davidsaver [mailto:[email protected]]
> Sent: Wednesday, December 27, 2017 6:11 PM
> To: Mark Rivers; 'Andrew Johnson'; [email protected]
> Subject: Re: Problem building example application on windows-x64
> > 2017-12-27T14:53:16.250 Receive thread for UDP socket 0.0.0.0:0 has not exited.
> Looks like osiSockAttach() isn't being called enough.
> It might be useful if you run
> > var atExitDebug 1
> in the IOC shell and then exit.  This should give some idea of which atexit
> handler is making the last osiSockRelease(), and which one should be.
Problem building example application on windows-x64 Mark Rivers
RE: Problem building example application on windows-x64 Mark Rivers
Re: Problem building example application on windows-x64 Andrew Johnson
Re: Problem building example application on windows-x64 Michael Davidsaver
Prev: Re: Problem building example application on windows-x64 Michael Davidsaver
Next: Re: Problem building example application on windows-x64 Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: genVersionHeader.pl timestamp granularity (was Re: Problem building example application on windows-x64) Michael Davidsaver
ANJ, 28 Dec 2017 · Home · News · About · Talk · Base · Modules · Extensions ·
