I have tested the fixes.
I did the following in module/pvData and modules/pvAccess
git checkout master
git pull
Rebuilt base for windows-x64 and windows-x64-static.
Rebuilt example application for both ARCHs.
It appears to fix both problems:
- windows-x64 no longer hangs with WINSOCK errors when exiting.
- windows-x64-static no longer crashes on startup.
Sent: Thursday, December 28, 2017 12:23 PM
To: Mark Rivers; 'Andrew Johnson'; '[email protected]'
Subject: Re: Problem building example application on windows-x64
I have committed possible fixes for the first two issues.
On 12/28/2017 09:37 AM, Michael Davidsaver wrote:
> So much for that. I manged to miss this issue. Time to open some tickets I think.
> So far I count four distinct symptoms, and the test failures.
> What I see so far:
> 1. Global ctor ordering issues needs to be opened against pvDataCPP and pvAccessCPP
> (any probably others).
https://github.com/epics-base/pvDataCPP/issues/49
w/ candidate fix
> 2. The osiSockAttach() issue against pvAccessCPP.
https://github.com/epics-base/pvAccessCPP/issues/81
w/ candidate fix
> 3. The Com.res failure against Base (on launchpad)
https://bugs.launchpad.net/bugs/1740408
> 4. The timestamp issue w/ genVersionHeader.pl against Base
tbd.
- Re: Problem building example application on windows-x64 Michael Davidsaver
- RE: Problem building example application on windows-x64 Mark Rivers
- Problem building example application on windows-x64 Mark Rivers
- Re: Problem building example application on windows-x64 Andrew Johnson
- Re: Problem building example application on windows-x64 Mark Rivers
<2017>
2025
2026
<2017>
2025
2026
