2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem building example application on windows-x64
To: Michael Davidsaver <[email protected]>, 'Andrew Johnson' <[email protected]>, "'[email protected]'" <[email protected]>
Date: Fri, 29 Dec 2017 14:55:42 +0000
I have run the runtests for windows-x64 and windows-x64-staticon VS2010.
For windows-x64 there were no dialog boxes.
For windows-x64-static there were many Debug Assertion error dialog boxes in testSerialization.t (24 times) and  testPVScalarArrat (5 times)
They all appear to be null pointer problems.
Both also appeared to fail some tests:
These are failures on windows-x64:
Test Summary Report
simmTest.t            (Wstat: 0 Tests: 1176 Failed: 7)
  Failed tests:  140, 315, 439-440, 665-666, 767
Files=11, Tests=3575, 13 wallclock secs ( 0.48 usr +  0.08 sys =  0.56 CPU)
Result: FAIL
Failed 1/11 test programs. 7/3575 subtests failed.
These are failures on windows-x64-static:
Test Summary Report
simmTest.t            (Wstat: 0 Tests: 1176 Failed: 3)
  Failed tests:  355-356, 439
Files=11, Tests=3575, 15 wallclock secs ( 0.50 usr +  0.03 sys =  0.53 CPU)
Result: FAIL
Failed 1/11 test programs. 3/3575 subtests failed.
This is the output for windows-x64:
H:\epics-devel\base-7.0.1>set EPICS_HOST_ARCH=windows-x64
H:\epics-devel\base-7.0.1>make -s runtests
Snippets.t .. ok
All tests successful.
Files=1, Tests=29,  2 wallclock secs ( 0.05 usr +  0.00 sys =  0.05 CPU)
Result: PASS
epicsUnitTestTest.t ........ ok
epicsTypesTest.t ........... ok
epicsInlineTest.t .......... ok
epicsCalcTest.t ............ ok
epicsAlgorithmTest.t ....... ok
epicsMathTest.t ............ ok
epicsMMIOTest.t ............ ok
epicsEllTest.t ............. ok
epicsEnvTest.t ............. ok
epicsErrlogTest.t .......... 24/32 log client: connected to log server at "127.0.0.1:60935"
epicsErrlogTest.t .......... ok
epicsStdioTest.t ........... ok
epicsStdlibTest.t .......... ok
epicsSockResolveTest.t ..... ok
epicsStringTest.t .......... ok
epicsTimeTest.t ............ ok
epicsTimeZoneTest.t ........ ok
epicsThreadTest.t .......... ok
epicsThreadOnceTest.t ...... ok
epicsThreadPriorityTest.t .. ok
epicsThreadPrivateTest.t ... ok
epicsThreadHooksTest.t ..... ok
epicsThreadPoolTest.t ...... ok
epicsExitTest.t ............ ok
epicsTimerTest.t ........... ok
ringPointerTest.t .......... ok
ringBytesTest.t ............ ok
epicsEventTest.t ........... ok
epicsMutexTest.t ........... ok
epicsSpinTest.t ............ ok
epicsAtomicTest.t .......... ok
macDefExpandTest.t ......... ok
cvtFastTest.t .............. ok
macLibTest.t ............... ok
macLib.t ................... ok
taskwdTest.t ............... ok
blockingSockTest.t ......... ok
epicsMessageQueueTest.t .... ok
epicsStackTraceTest.t ...... ok
ipAddrToAsciiTest.t ........ ok
osiSockTest.t .............. ok
Files=40, Tests=4016, 200 wallclock secs ( 0.56 usr +  0.16 sys =  0.72 CPU)
Result: PASS
dbScanTest.t ............... ok
dbShutdownTest.t ........... ok
dbPutLinkTest.t ............ 265/320 dbJLinkInit: lexical error: invalid char in json text.
                                  {"x":bbbb}
                     (right here) ------^
dbJLinkInit: parse error: premature EOF
                                       {"z":{"good":6}
dbPutLinkTest.t ............ ok
dbLockTest.t ............... ok
dbStressTest.t ............. ok
testdbConvert.t ............ ok
callbackTest.t ............. ok
callbackParallelTest.t ..... ok
dbStateTest.t .............. ok
dbServerTest.t ............. 1/24 dbRegisterServer: 'one' registered twice?
dbRegisterServer: Bad server name 'bad name'
dbRegisterServer: Ignoring 'disabled', per environment
dbUnregisterServer: Servers still active!
dbUnregisterServer: 'toolate' not registered.
dbUnregisterServer: 'no-routines' has no stop() method.
dbServerTest.t ............. ok
dbCaStatsTest.t ............ ok
dbCaLinkTest.t ............. ok
scanIoTest.t ............... ok
dbChannelTest.t ............ ok
dbChArrTest.t .............. Starting iocInit
dbChArrTest.t .............. ok
chfPluginTest.t ............ 1/1433 chfConfigParseStart: plugin pvt alloc failed
chfPluginTest.t ............ ok
arrShorthandTest.t ......... ok
recGblCheckDeadbandTest.t .. ok
testPutGetTest.t ........... ok
dbStaticTest.t ............. ok
Files=20, Tests=2856, 81 wallclock secs ( 0.41 usr +  0.11 sys =  0.51 CPU)
Result: PASS
msi.t .. ok
Files=1, Tests=9,  1 wallclock secs ( 0.03 usr +  0.00 sys =  0.03 CPU)
Result: PASS
arrayOpTest.t ........... ok
recMiscTest.t ........... ok
linkRetargetLinkTest.t .. ok
linkInitTest.t .......... 1/77 dbRegisterServer: 'rsrv' registered twice?
linkInitTest.t .......... 18/77 dbRegisterServer: 'rsrv' registered twice?
linkInitTest.t .......... 60/77 dbRegisterServer: 'rsrv' registered twice?
linkInitTest.t .......... ok
compressTest.t .......... 1/116 dbRegisterServer: 'rsrv' registered twice?
compressTest.t .......... ok
asyncSoftTest.t ......... ok
softTest.t .............. ok
asTest.t ................ ok
analogMonitorTest.t ..... Starting iocInit
analogMonitorTest.t ..... ok
regressTest.t ........... 1/31 dbRegisterServer: 'rsrv' registered twice?
dbConvertJSON: parse error: trailing garbage
                                      0x10
                                      0x10
                                      0x10
                                      0x10
                                      0x10
                                      0x10
                                      0x10
                                      0x10
regressTest.t ........... ok
simmTest.t .............. Failed 7/1176 subtests
Test Summary Report
Result: FAIL
tsTest.t .... ok
dbndTest.t .. ok
arrTest.t ... ok
syncTest.t .. ok
Files=4, Tests=1612,  3 wallclock secs ( 0.19 usr +  0.01 sys =  0.20 CPU)
Result: PASS
Base.t ........ ok
Breaktable.t .. ok
DBD.t ......... ok
Device.t ...... ok
Driver.t ...... ok
Function.t .... ok
Menu.t ........ ok
Recfield.t .... ok
Recordtype.t .. ok
Registrar.t ... ok
Variable.t .... ok
Files=11, Tests=287,  1 wallclock secs ( 0.03 usr +  0.06 sys =  0.09 CPU)
Result: PASS
testThread.t ............ ok
testEvent.t ............. ok
testTimer.t ............. ok
testBitSet.t ............ ok
testOverrunBitSet.t ..... ok
testByteBuffer.t ........ ok
testBaseException.t ..... ok
testSharedVector.t ...... ok
testDebugPtr.t .......... ok
testSerialization.t ..... ok
testTimeStamp.t ......... ok
testQueue.t ............. ok
testTypeCast.t .......... ok
testUnitTest.t .......... ok
testjson.t .............. ok
test_reftrack.t ......... ok
testanyscalar.t ......... ok
testBitSetUtil.t ........ ok
testIntrospect.t ........ ok
testPVType.t ............ ok
testStandardField.t ..... ok
testStandardPVField.t ... ok
testPVData.t ............ ok
testPVUnion.t ........... ok
testConvert.t ........... ok
testPVScalarArray.t ..... ok
testPVStructureArray.t .. ok
testOperators.t ......... ok
testFieldBuilder.t ...... ok
testValueBuilder.t ...... ok
testProperty.t .......... ok
testCreateRequest.t ..... ok
testPVCopy.t ............ ok
Files=33, Tests=2248, 12 wallclock secs ( 0.50 usr +  0.06 sys =  0.56 CPU)
Result: PASS
testAtomicBoolean.t ..... ok
testHexDump.t ........... ok
testInetAddressUtils.t .. ok
configurationTest.t ..... ok
testFairQueue.t ......... ok
testWildcard.t .......... ok
testChannelAccess.t ..... ok
testCodec.t ............. ok
testRPC.t ............... ok
testServerContext.t ..... ok
Files=10, Tests=6192, 30 wallclock secs ( 0.44 usr +  0.01 sys =  0.45 CPU)
Result: PASS
ntfieldTest.t ............... ok
ntscalarTest.t .............. ok
ntscalarArrayTest.t ......... ok
ntnameValueTest.t ........... ok
ntmultiChannelTest.t ........ ok
ntscalarMultiChannelTest.t .. ok
nttableTest.t ............... ok
ntndarrayTest.t ............. ok
ntmatrixTest.t .............. ok
ntenumTest.t ................ ok
ntunionTest.t ............... ok
ntaggregateTest.t ........... ok
ntattributeTest.t ........... ok
ntndarrayAttributeTest.t .... ok
ntcontinuumTest.t ........... ok
nthistogramTest.t ........... ok
ntutilsTest.t ............... ok
Files=17, Tests=631,  3 wallclock secs ( 0.27 usr +  0.09 sys =  0.36 CPU)
Result: PASS
testPVCopy.t ......... ok
testPVRecord.t ....... ok
testExampleRecord.t .. ok
testLocalProvider.t .. ok
testPVAServer.t ...... ok
Files=5, Tests=81,  1 wallclock secs ( 0.06 usr +  0.03 sys =  0.09 CPU)
Result: PASS
testmon.t .. ok
Files=1, Tests=79,  0 wallclock secs ( 0.05 usr +  0.01 sys =  0.06 CPU)
Result: PASS
testweak.t .. ok
testtest.t .. ok
testpvif.t .. 1/71 Command stopPVAServer not found.
testpvif.t .. ok
testpdb.t ... ok
Files=4, Tests=247,  2 wallclock secs ( 0.08 usr +  0.05 sys =  0.12 CPU)
Result: PASS
This is for windows-x64-static
H:\epics-devel\base-7.0.1>set EPICS_HOST_ARCH=windows-x64-static
Snippets.t .. ok
Files=1, Tests=29,  2 wallclock secs ( 0.03 usr +  0.00 sys =  0.03 CPU)
Result: PASS
epicsErrlogTest.t .......... 25/32 log client: connected to log server at "127.0.0.1:61307"
Test Summary Report
epicsMathTest.t          (Wstat: 0 Tests: 35 Failed: 0)
  TODO passed:   8-9, 11-12, 22-23
Files=40, Tests=4016, 204 wallclock secs ( 0.56 usr +  0.16 sys =  0.72 CPU)
Result: PASS
                                  {"x":bbbb}
                                       {"z":{"good":6}
dbServerTest.t ............. dbRegisterServer: 'one' registered twice?
dbServerTest.t ............. 1/24 dbRegisterServer: Bad server name 'bad name'
Files=20, Tests=2856, 82 wallclock secs ( 0.51 usr +  0.08 sys =  0.59 CPU)
Result: PASS
msi.t .. ok
Files=1, Tests=9,  0 wallclock secs ( 0.03 usr +  0.02 sys =  0.05 CPU)
Result: PASS
linkInitTest.t .......... 8/77 dbRegisterServer: 'rsrv' registered twice?
                                      0x10
                                      0x10
                                      0x10
                                      0x10
                                      0x10
                                      0x10
                                      0x10
                                      0x10
regressTest.t ........... 6/31 dbRegisterServer: 'rsrv' registered twice?
simmTest.t .............. Failed 3/1176 subtests
Test Summary Report
Result: FAIL
tsTest.t .... ok
dbndTest.t .. ok
arrTest.t ... ok
syncTest.t .. ok
Files=4, Tests=1612,  3 wallclock secs ( 0.19 usr +  0.00 sys =  0.19 CPU)
Result: PASS
Base.t ........ ok
Breaktable.t .. ok
DBD.t ......... ok
Device.t ...... ok
Driver.t ...... ok
Function.t .... ok
Menu.t ........ ok
Recfield.t .... ok
Recordtype.t .. ok
Registrar.t ... ok
Variable.t .... ok
Files=11, Tests=287,  1 wallclock secs ( 0.00 usr +  0.01 sys =  0.01 CPU)
Result: PASS
Files=33, Tests=2248, 294 wallclock secs ( 0.64 usr +  0.11 sys =  0.75 CPU)
Result: PASS
Files=10, Tests=6192, 28 wallclock secs ( 0.48 usr +  0.05 sys =  0.53 CPU)
Result: PASS
Files=17, Tests=631,  3 wallclock secs ( 0.14 usr +  0.08 sys =  0.22 CPU)
Result: PASS
Files=5, Tests=81,  2 wallclock secs ( 0.03 usr +  0.01 sys =  0.05 CPU)
Result: PASS
testmon.t .. ok
Result: PASS
testweak.t .. ok
testtest.t .. ok
testpvif.t .. ok
testpdb.t ... ok
Files=4, Tests=247,  4 wallclock secs ( 0.08 usr +  0.02 sys =  0.09 CPU)
Result: PASS
Sent: Friday, December 29, 2017 8:06 AM
To: Michael Davidsaver; 'Andrew Johnson'; '[email protected]'
Subject: Re: Problem building example application on windows-x64
I have tested the fixes.
I did the following in module/pvData and modules/pvAccess
git checkout master
git pull
Rebuilt base for windows-x64 and windows-x64-static.
Rebuilt example application for both ARCHs.
It appears to fix both problems:
- windows-x64 no longer hangs with WINSOCK errors when exiting.
- windows-x64-static no longer crashes on startup.
Sent: Thursday, December 28, 2017 12:23 PM
To: Mark Rivers; 'Andrew Johnson'; '[email protected]'
I have committed possible fixes for the first two issues.
On 12/28/2017 09:37 AM, Michael Davidsaver wrote:
> So much for that.  I manged to miss this issue.  Time to open some tickets I think.
> So far I count four distinct symptoms, and the test failures.
> What I see so far:
> 1. Global ctor ordering issues needs to be opened against pvDataCPP and pvAccessCPP
>    (any probably others).
https://github.com/epics-base/pvDataCPP/issues/49
w/ candidate fix
> 2. The osiSockAttach() issue against pvAccessCPP.
https://github.com/epics-base/pvAccessCPP/issues/81
w/ candidate fix
> 3. The Com.res failure against Base (on launchpad)
https://bugs.launchpad.net/bugs/1740408
> 4. The timestamp issue w/ genVersionHeader.pl against Base
tbd.
Re: Problem building example application on windows-x64 Michael Davidsaver
Problem building example application on windows-x64 Mark Rivers
RE: Problem building example application on windows-x64 Mark Rivers
Re: Problem building example application on windows-x64 Andrew Johnson
Re: Problem building example application on windows-x64 Mark Rivers
Prev: Re: Problem building example application on windows-x64 Michael Davidsaver
Next: Re: Problem building example application on windows-x64 Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 29 Dec 2017 · Home · News · About · Talk · Base · Modules · Extensions ·
