Do the unittests pass now?
On 12/29/2017 08:06 AM, Mark Rivers wrote:
> I have tested the fixes.
> I did the following in module/pvData and modules/pvAccess
> git checkout master
> git pull
> Rebuilt base for windows-x64 and windows-x64-static.
> Rebuilt example application for both ARCHs.
> It appears to fix both problems:
> - windows-x64 no longer hangs with WINSOCK errors when exiting.
> - windows-x64-static no longer crashes on startup.
> Thanks,
> Mark
> ________________________________
> From: Michael Davidsaver <[email protected]>
> Sent: Thursday, December 28, 2017 12:23 PM
> To: Mark Rivers; 'Andrew Johnson'; '[email protected]'
> Subject: Re: Problem building example application on windows-x64
> I have committed possible fixes for the first two issues.
> On 12/28/2017 09:37 AM, Michael Davidsaver wrote:
>> So much for that. I manged to miss this issue. Time to open some tickets I think.
>> So far I count four distinct symptoms, and the test failures.
>> What I see so far:
>> 1. Global ctor ordering issues needs to be opened against pvDataCPP and pvAccessCPP
>> (any probably others).
> https://github.com/epics-base/pvDataCPP/issues/49
> w/ candidate fix
>> 2. The osiSockAttach() issue against pvAccessCPP.
> https://github.com/epics-base/pvAccessCPP/issues/81
> w/ candidate fix
>> 3. The Com.res failure against Base (on launchpad)
> https://bugs.launchpad.net/bugs/1740408
>> 4. The timestamp issue w/ genVersionHeader.pl against Base
> tbd.
- Problem building example application on windows-x64 Mark Rivers
- RE: Problem building example application on windows-x64 Mark Rivers
- Re: Problem building example application on windows-x64 Andrew Johnson
- Re: Problem building example application on windows-x64 Michael Davidsaver
- Re: Problem building example application on windows-x64 Mark Rivers
<2017>
2025
2026
<2017>
2025
2026
