2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build error for windows-x64-debug on VS2010
To: <[email protected]>, EPICS core-talk <[email protected]>
Date: Wed, 7 Feb 2018 11:56:58 -0600
Hi Freddie,
On 02/07/2018 08:26 AM, [email protected] wrote:
> To remove the "brute force" it might be possible to use a
> "makedepend" type tool to generate the list of external
> headers used by a particular source file and then make sure
> that these are mentioned before the <epicsExport.h> etc.
The list of headers is already available in the .d file that the build
system generates inside the O.<arch> directory for each .c and .cpp
file. Writing a tool that checks the includes compared to where
epicsExportSharedSymbols gets defined sounds like an interesting idea,
maybe a project for a summer student if anyone has one...
> The most bulletproof approach, however, would be to protect
> headers as per the comments in the EPICS <shareLib.h>  file
> so that import/export are swapped automatically.
I disagree that the #ifdef epicsExportSharedSymbols thing discussed in
shareLib.h is bulletproof. In my experience that construct actually
makes it much harder to track down the location of any mistakes.
It is usually relatively easy to find a source file which has an include
in the wrong place (above/below the #define epicsExportSharedSymbols or
#include <epicsExport.h> statement) because the error is usually
reported in the build or link of that file and gives the name of a
symbol which is in or related to the include file that needs to be moved.
With the other approach the error is actually in a header file, and no
indication is given at compile-time which header needs to be fixed. This
approach also clutters up the header files with this weird conditional
construct, and it doesn't take away the need to get the includes right
in the source file (look at dbEvent.h and src/ioc/db/dbEvent.c for an
example).
Here's the error message that Mark reported:
> pvAccess.lib(pvAccess.dll) : error LNK2005: "public: virtual __cdecl
> epics::pvAccess::ChannelFind::~ChannelFind(void)"
> (??1ChannelFind@pvAccess@epics@@UEAA@XZ) already defined in qsrv.obj
> pvAccess.lib(pvAccess.dll) : error LNK2005: "public: __cdecl epics::pvAccess::ChannelFind::ChannelFind(void)" (??0ChannelFind@pvAccess@epics@@QEAA@XZ) already defined in qsrv.obj
>    Creating library qsrv.lib and object qsrv.exp qsrv.dll : fatal
> error LNK1169: one or more multiply defined symbols found
This tells me that whatever header file declares the routine
is probably listed the wrong side of the epicsExportSharedSymbols
definition inside the source file that created qsrv.obj. Sure enough,
Mark reported the error was fixed by your change to qsrv.cpp (which
moves the #include <epicsExport.h> that also defines the macro
epicsExportSharedSymbols; I would like to change that, but it would
require so many updates to out-of-tree code that I think it would be too
painful to do).
The only difficulty is generally remembering that this kind of error is
caused by the include order in the source file. What I don't understand
is why the compiler wasn't complaining about any other symbols defined
in headers that were also the wrong side of #include <epicsExport.h>,
but I've given up trying to understand Microsoft's compiler.
- Andrew
Build error for windows-x64-debug on VS2010 Mark Rivers
Re: Build error for windows-x64-debug on VS2010 Michael Davidsaver
RE: Build error for windows-x64-debug on VS2010 Mark Rivers
RE: Build error for windows-x64-debug on VS2010 freddie.akeroyd
Prev: Re: Build error for windows-x64-debug on VS2010 Michael Davidsaver
Next: Epics Core 7 & Submodules Hugo Slepicka
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Build error for windows-x64-debug on VS2010 Michael Davidsaver
ANJ, 07 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
