On 04/18/2018 09:58 AM, Andrew Johnson wrote:
> On 04/18/2018 12:17 AM, Michael Davidsaver wrote:
>> On 04/17/2018 09:31 PM, Johnson, Andrew N. wrote:
>>> Why wouldn’t you put the workaround in the file CONFIG.Common.RTEMS
>>> where you don’t need a conditional test?
>> Do you mean in Base or external modules? If Base, then because I wanted
>> to hear from you first. If external, I don't think this works with
>> $(OS_CLASS) granularity.
> I was meaning in Base, I didn't consider if the issue might be in an
> external module.
Another factor is that the generated headers are being placed in ../O.Common/pv/
whereas in Base, epicsVersion.h is placed in ../O.Common which has presumably
already been created as makeEpicsVersion.pl doesn't try to do this.
>>> I haven’t looked into why you’re only just noticing this now, but there
>>> are a few possibilities that I could come up with.
>> My guess is that it will come down to a mixture of not enough RTEMS/vxworks
>> builds, with a dose of GNUMake trivia thrown in.
> What are the rules you're using to generate these files? See below...
https://github.com/epics-base/pvDataCPP/blob/master/src/Makefile#L34-L36
https://github.com/epics-base/pvAccessCPP/blob/master/src/Makefile#L41-L43
And now
https://github.com/mdavidsaver/pva2pva/blob/master/pdbApp/Makefile#L83-L85
>> I noticed this when adding a new generated header in pva2pva. At first
>> I assumed it was a dep. problem on my end. However, while a clean
>> sequential (not -j) build was always successful. A clean parallel build
>> would sometimes fail. When it did fail, a sequential rebuild would also
>> fail. Which is when I noticed the missing '-p'.
> I know what you're doing wrong, please generate those version headers in
> the host build only and *not* in the other build targets. Why?
Ok, fair enough. I didn't start with this mostly because the rule for
epicsVersion.h doesn't. Although presumably it should, for the reasons you
give.
Is this a case for
> ifeq ($(T_A),$(EPICS_HOST_ARCH))
or something more clever?
- obscure EPICS+RTEMS makefile problem Michael Davidsaver
- Re: obscure EPICS+RTEMS makefile problem Johnson, Andrew N.
- Re: obscure EPICS+RTEMS makefile problem Michael Davidsaver
- Re: obscure EPICS+RTEMS makefile problem Andrew Johnson
DBRecord client access Marty Kraimer
<2018>
2025
2026
PVA links alpha Michael Davidsaver
<2018>
2025
2026
