2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RTEMS-5 integration
From: "Williams Jr., Ernest L." <[email protected]>
To: Ralph Lange <[email protected]>, Benjamin Franksen <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Tue, 26 Jun 2018 15:59:19 +0000
Hi Ralph,
Can I just proceed with the following and pickup these changes?
git pull
git submodule update --remote
Cheers,
Ernest
From: [email protected] <[email protected]> on behalf of Ralph Lange <[email protected]>
Sent: Tuesday, June 26, 2018 8:34 AM
To: Benjamin Franksen
Cc: EPICS Core Talk
The repositories of the modules (core, libcom, database, ca) that were separate branches on the epics-core repo have been merged (recombined), without changing the file structure.
The resulting new-focus-of-attention branch is called '7.0' (in line with the other release series' branch names).
You can try to merge the request for core straight into 7.0 - in that case the structure has not changed.
For the libcom request, the underlying structure has changed, so you would either have to move everything into modules/libcom on the proposal branch before trying to merge, or create a set of patch files that you can try to apply to a 7.0 clone while being in modules/libcom.
Lots of overhead, I know. But it is the only merge request that is affected.
Cheers,
~Ralph
On Tue, Jun 26, 2018 at 5:24 PM Benjamin Franksen <[email protected]> wrote:
On 06/26/2018 01:40 PM, Ralph Lange wrote:
> Merge Proposals are at
> https://code.launchpad.net/epics-base/+activereviews
Thanks.
> Heinz' RTEMS branch needs some clean-up and minimization - there are
> comments in the merge proposals that name some places.
Okay, I have read Michael's comments.
> Note that the two MPs are actually one (again), as we recently
> dropped the split-up of repo-branches for the modules formerly known
> as EPICS V3.
Nice. It looks as if the rtems5 branch is a bit behind, though, it still
has submodules for these parts.
> I was volunteering to help him do this, but it would actually be
> great if you could jump in. My arguments (same language and time
> zone) cover you in the same way, and you have a much better
> justification (as ITER does not intend to use RTEMS).
The first thing to do would be to bring the rtems5 branch up to date
with core/master. I tried to merge hj/rtems5 which succeeded but of
course that gave me only a few changes in configure. I then tried to
merge hj/rtems5libcom but that failed horribly with thousands of
rename/delete conflicts. My git-fu is rather weak so I guess my naive
attempts were doomed from the beginning...
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Re: How to move to the new 7.0 branch (was: RTEMS-5 integration) Ralph Lange
RTEMS-5 integration Benjamin Franksen
Re: RTEMS-5 integration Ralph Lange
Re: RTEMS-5 integration Benjamin Franksen
Prev: Re: RTEMS-5 integration Ralph Lange
Next: Re: RTEMS-5 integration Heinz Junkes
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: How to move to the new 7.0 branch (was: RTEMS-5 integration) Ralph Lange
ANJ, 27 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
