2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RTEMS-5 integration
To: Ralph Lange <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Tue, 26 Jun 2018 20:34:15 +0200
Hello Benjamin,
Do not make the effort.
I will create a new merge request for the ‘dereorganized' repo.
I will also try to address the issues raised by Michael. Especially the question about osdThread.c from the posix branch
For safety's sake, I created my own osdThread.c for RTEMS5. There was a serious bug (https://devel.rtems.org/ticket/3243)
which has been fixed in the meantime. I'll try it now with the existing posix/osdThread.c. But I'm on the road for the next 1.5
weeks and will come to it later.
Heinz
> On 26. Jun 2018, at 17:34, Ralph Lange <[email protected]> wrote:
> The repositories of the modules (core, libcom, database, ca) that were separate branches on the epics-core repo have been merged (recombined), without changing the file structure.
> The resulting new-focus-of-attention branch is called '7.0' (in line with the other release series' branch names).
> You can try to merge the request for core straight into 7.0 - in that case the structure has not changed.
> For the libcom request, the underlying structure has changed, so you would either have to move everything into modules/libcom on the proposal branch before trying to merge, or create a set of patch files that you can try to apply to a 7.0 clone while being in modules/libcom.
> Lots of overhead, I know. But it is the only merge request that is affected.
> Cheers,
> ~Ralph
> On Tue, Jun 26, 2018 at 5:24 PM Benjamin Franksen <[email protected]> wrote:
> On 06/26/2018 01:40 PM, Ralph Lange wrote:
> > Merge Proposals are at
> > https://code.launchpad.net/epics-base/+activereviews
> Thanks.
> > Heinz' RTEMS branch needs some clean-up and minimization - there are
> > comments in the merge proposals that name some places.
> Okay, I have read Michael's comments.
> > Note that the two MPs are actually one (again), as we recently
> > dropped the split-up of repo-branches for the modules formerly known
> > as EPICS V3.
> Nice. It looks as if the rtems5 branch is a bit behind, though, it still
> has submodules for these parts.
> > I was volunteering to help him do this, but it would actually be
> > great if you could jump in. My arguments (same language and time
> > zone) cover you in the same way, and you have a much better
> > justification (as ITER does not intend to use RTEMS).
> The first thing to do would be to bring the rtems5 branch up to date
> with core/master. I tried to merge hj/rtems5 which succeeded but of
> course that gave me only a few changes in configure. I then tried to
> merge hj/rtems5libcom but that failed horribly with thousands of
> rename/delete conflicts. My git-fu is rather weak so I guess my naive
> attempts were doomed from the beginning...
> Cheers
> Ben
> "Make it so they have to reboot after every typo." ― Scott Adams
Attachment: smime.p7s
Description: S/MIME cryptographic signature
RTEMS-5 integration Benjamin Franksen
Re: RTEMS-5 integration Ralph Lange
Re: RTEMS-5 integration Benjamin Franksen
Prev: Re: RTEMS-5 integration Williams Jr., Ernest L.
Next: Re: How to move to the new 7.0 branch (was: RTEMS-5 integration) Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How to move to the new 7.0 branch (was: RTEMS-5 integration) Williams Jr., Ernest L.
Next: Build failed in Jenkins: epics-base-3.16-mac-test #206 APS Jenkins
ANJ, 27 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
