2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PVD/PVA: Examples for multi-dimensional arrays?
From: Marty Kraimer via Core-talk <[email protected]>
To: [email protected]
Date: Wed, 21 Nov 2018 15:32:54 -0500
On 11/21/18 11:10 AM, Ralph Lange via Core-talk wrote:
Hi Mark,
On Wed, 21 Nov 2018 at 16:37, Mark Rivers <[email protected]> wrote:
What do you mean by "support"?  NTNDArrays are certainly N-dimensional.  Do you want the API to allow extracting rows/columns, etc.?
Hm.
The problem with leaving n-dim support to the application is that every application using n-dim arrays will have to do its own implementation of the accessors. Also, because of that, these n-dim arrays will likely not be compatible between applications.
Does that sound like I am asking for a new normative type?
Cheers,
~Ralph
At the very beginning of PVData development, i. e. the JavaIOC, a deliberate decision was made that pvData would only support 1 dim arrays.
The problem with supporting more dimensions is how many and how to define each dimension.
Just consider a 2d array. It it a 2d matrix? Is it a sparse  matrix? Is it a table?
I also remember a request for pvData defining a map type.
Where do we stop?
At the very beginning it was decided that the following types would be supported
1) scalars of numeric , boolean, and string.
2) 1d arrays of each scalar type
3) structures
4) 1d structure arrays
This was defined in 2006.
The only types that were added later are:
5) union
6) 1d union array.
It is ONLY data of  above types that need to be supported by the pva network protocol.
Also from the beginning it was assumed that more complex types would be supported via structure definitions.
This later became the normative types.
Note that normative types already has definiintions for NTTable, NTMatrix, and NTHistogram.
Each of these is a different type of 2d array.
NTNDArray includes a multi dimensional array plus lots more.
No normative type required any changes to the network protocol.
Recently there was a discussion of pvAccess directly supporting  compression.
Although it was talking about pvAccess it would probably have to involve pvData.
For the same reason for not supporting multi deminsional array compression should NOT be directly supported by pvData/pvAccess.
What kind of compression?
lossless?, JPEG?, etc, etc.
Would each additional type require changes to the pva network protocol.
Note that areaDetecter already supports a few compression types.
Marty
Re: PVD/PVA: Examples for multi-dimensional arrays? Mark Rivers via Core-talk
PVD/PVA: Examples for multi-dimensional arrays? Ralph Lange via Core-talk
Re: PVD/PVA: Examples for multi-dimensional arrays? Michael Davidsaver via Core-talk
Re: PVD/PVA: Examples for multi-dimensional arrays? Ralph Lange via Core-talk
Prev: Re: PVD/PVA: Examples for multi-dimensional arrays? Michael Davidsaver via Core-talk
Next: Jenkins build is back to normal : EPICS-7 #166 Jenkins EPICS PSI via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Re: PVD/PVA: Examples for multi-dimensional arrays? Mark Rivers via Core-talk
ANJ, 21 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
