2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Working on the 7.0.2 final release
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Tue, 18 Dec 2018 20:03:31 +0000
On 12/18/18 1:44 PM, Mark Rivers wrote:
>> You should just be able to delete those files for all your host architectures and they will be recreated when you next run make on that arch.
> Yes, that worked.  But shouldn't "make clean" remove those files?  I should not have to manually remove files when I update to a new version and rename the directory?
Good question. The 'realclean' target does delete that file for the
current host-arch, but the basic 'clean' target does not, and if you had
built for multiple host architectures in the same tree you would have to
do a 'make realclean' or 'make distclean' for each host for all the
files to be deleted, which is obviously not ideal behaviour. I will fix
the latter so all RELEASE.*.local files get removed, but I want to leave
this as a 'realclean' (or 'distclean') action.
Thanks for finding the first bug before I've even sent out the release
announcement!
- Andrew
RE: Working on the 7.0.2 final release Mark Rivers via Core-talk
Working on the 7.0.2 final release Johnson, Andrew N. via Core-talk
Re: Working on the 7.0.2 final release Johnson, Andrew N. via Core-talk
Prev: RE: Working on the 7.0.2 final release Mark Rivers via Core-talk
Next: RE: Working on the 7.0.2 final release Mark Rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 18 Dec 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
