> The 'realclean' target does delete that file for the current host-arch,
I believe I typed
make -sj realclean realuninstall
But that command itself generated an error about the missing 7.0.1 directory.
-----Original Message-----
Sent: Tuesday, December 18, 2018 2:04 PM
To: Mark Rivers <[email protected]>
Cc: '[email protected]' <[email protected]>
Subject: Re: Working on the 7.0.2 final release
On 12/18/18 1:44 PM, Mark Rivers wrote:
>> You should just be able to delete those files for all your host architectures and they will be recreated when you next run make on that arch.
> Yes, that worked. But shouldn't "make clean" remove those files? I should not have to manually remove files when I update to a new version and rename the directory?
Good question. The 'realclean' target does delete that file for the current host-arch, but the basic 'clean' target does not, and if you had built for multiple host architectures in the same tree you would have to do a 'make realclean' or 'make distclean' for each host for all the files to be deleted, which is obviously not ideal behaviour. I will fix the latter so all RELEASE.*.local files get removed, but I want to leave this as a 'realclean' (or 'distclean') action.
Thanks for finding the first bug before I've even sent out the release announcement!
- Andrew
Arguing for surveillance because you have nothing to hide is no different than making the claim, "I don't care about freedom of speech because I have nothing to say." -- Edward Snowdon
- Re: Working on the 7.0.2 final release Johnson, Andrew N. via Core-talk
- Working on the 7.0.2 final release Johnson, Andrew N. via Core-talk
- RE: Working on the 7.0.2 final release Mark Rivers via Core-talk
Re: Working on the 7.0.2 final release Konrad, Martin via Core-talk
<2018>
2025
2026
<2018>
2025
2026
