2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Working on the 7.0.2 final release
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Tue, 18 Dec 2018 20:42:11 +0000
On 12/18/18 2:15 PM, Mark Rivers wrote:
The 'realclean' target does delete that file for the current host-arch,
I believe I typed
make -sj realclean realuninstall
But that command itself generated an error about the missing 7.0.1 directory.
Yes, you would have had to run the 'realclean' command before moving the tree, then it would have worked. Or use Martin Konrad's git command.
This RELEASE.<host>.local file is needed for builds of our sub-modules to be able to find their build rules and install location. Support modules can't assume EPICS_BASE is at $(TOP)/../.. because if someone sets INSTALL_LOCATION in their base/configure/CONFIG_SITE file it won't be. Sites using the same build tree to support multiple host architectures with different mount paths is why the file has to be host-specific, and it also has to give an absolute path because the RELEASE files get pulled in by every Makefile in the source tree.
- Andrew
Working on the 7.0.2 final release Johnson, Andrew N. via Core-talk
Re: Working on the 7.0.2 final release Johnson, Andrew N. via Core-talk
RE: Working on the 7.0.2 final release Mark Rivers via Core-talk
Prev: Re: Working on the 7.0.2 final release Konrad, Martin via Core-talk
Next: Re: Working on the 7.0.2 final release Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Working on the 7.0.2 final release Mark Rivers via Core-talk
Next: Re: Working on the 7.0.2 final release Konrad, Martin via Core-talk
ANJ, 18 Dec 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
