On 02.04.19 18:15, Michael Davidsaver wrote:
Could you add something concerning the application which is call errSymbolAdd()?
It it published anywhere?
The code in question is the ik320 driver by Till Straumann from 1999.
It can be found here:
https://github.com/epics-modules/vme/blob/master/vmeApp/src/drvIK320ErrStat.c
I had modified the driver not to depend on vxWorks any more (as we have
Linux VME systems) and to use EPICS osi functions. All worked well until
newer gcc versions complained about missing function prototypes and
warned that in future this will be an error. When I wanted to add the
header file for errSymbolAdd() I found that the required file name has
changed in EPICS 7.
This kind of change makes the code a bit ugly because I had to add:
#include <epicsVersion.h>
#if EPICS_VERSION >= 7
#include <errSymTbl.h>
#else
#include <errMdef.h>
#endif
With most other drivers I have converted from 3.13/vxWorks to 3.14+/osi,
I only had to add includes which used to be included indirectly by other
headers but are not any more in newer EPICS versions. This was usually
no problem, because the header files used already existed in earlier
EPICS versions and thus the driver still compiled with earlier versions.
However now I have the situation where I need a header file in EPICS 7
which did not exist in EPICS 3.
- EPICS 7 incompatibility in errMdef.h Dirk Zimoch via Core-talk
- Re: EPICS 7 incompatibility in errMdef.h Dirk Zimoch via Core-talk
- Re: EPICS 7 incompatibility in errMdef.h Michael Davidsaver via Core-talk
Re: [Merge] ~bhill/epics-base:pvAccess-envDefs.h into epics-base:7.0 Bruce Hill via Core-talk
<2019>
2025
2026
Re: EPICS 7 incompatibility in errMdef.h Johnson, Andrew N. via Core-talk
<2019>
2025
2026
