2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 7 incompatibility in errMdef.h
From: Dirk Zimoch via Core-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>, EPICS Core Talk <[email protected]>
Date: Wed, 3 Apr 2019 10:25:59 +0200
On 02.04.19 19:37, Johnson, Andrew N. wrote:
Hi Dirk,
On 4/2/19 9:24 AM, Dirk Zimoch via Core-talk wrote:
The function definition errSymbolAdd() (and others) have disappeared from errMdef.h. Thus when compiling a driver including errMdef.h and using errSymbolAdd(), I get a compiler warning because of the missing function prototype.
The prototypes are now in the new header file errSymTbl.h. But simply including the new file instead is no good solution, because then the driver does not compile with older EPICS versions any more.
Instead I have use compiler branches based on EPICS versions. That is a bit inconvenient.
Not sure what you mean by "compiler branches" there.
I meant preprocessor branches: #if EPICS_VERSION >= 7
You could do this:
#include <errMdef.h>
#ifndef M_syd
#include <errSymTbl.h>
#endif
I believe the M_syd macro has not been used since before I started with EPICS. The comment for it said "Sync Data Routines; see sydDefs.h" but that header has not been present in any 3.13 release so I finally deleted that symbol while restructuring the libcom/src/error files.
Alternatively you could do a version number check (see the other epicsVersion.h thread for details) but the above suggestion is simpler and faster.
M_syd does not exist in 7.0.1. Also M_* macros seem to come and go. For example M_ts disappears. So this type of branching would be not only obfuscating the real reason for the branch but would also be unstable against future changes.
Instead I did the second alternative, branching on EPICS_VERSION.
- Andrew
Re: EPICS 7 incompatibility in errMdef.h Johnson, Andrew N. via Core-talk
EPICS 7 incompatibility in errMdef.h Dirk Zimoch via Core-talk
Prev: Re: EPICS 7 incompatibility in errMdef.h Dirk Zimoch via Core-talk
Next: a question on a commit comment Jeong Han Lee via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS 7 incompatibility in errMdef.h Johnson, Andrew N. via Core-talk
Next: Re: EPICS 7 incompatibility in errMdef.h Johnson, Andrew N. via Core-talk
ANJ, 03 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
