2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsThreadSleep and epicsThreadSleepQuantum
From: "Konrad, Martin via Core-talk" <[email protected]>
To: Mark Rivers <[email protected]>, "Johnson, Andrew N." <[email protected]>
Date: Fri, 14 Jun 2019 20:44:07 +0000
Hi Mark,
> The final run sleeps for 0 seconds.  Note it ran for 183936 loops,
> and used 0.78 seconds of CPU time.
Sure, waking up less often is more CPU efficient. On the other hand
sleeping for too long adds unnecessary latency (which might hurt if
this is happening in a loop).
I guess the moral of the story is that developers need to think about
how long they actually want to sleep. If something usually takes ~5 ms
on a typical machine waking up every ~1 ms might be a good compromise.
However, blindly trusting epicsThreadSleepQuantum() (which according to
the documentation is allowed to return 0) never seems to be an adequate
choice (at least not for libraries that are being used on very different
machines).
> It seems that having some idea of what the minimum effective sleep
> time is would be better than using 0, since that clearly uses a lot
> of CPU time.
I agree, epicsThreadSleep(0) only makes sense if you want to enforce a
context switch. Otherwise you better come up with a time.
-Martin
Martin Konrad
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
epicsThreadSleep and epicsThreadSleepQuantum Konrad, Martin via Core-talk
Re: epicsThreadSleep and epicsThreadSleepQuantum Konrad, Martin via Core-talk
RE: epicsThreadSleep and epicsThreadSleepQuantum Mark Rivers via Core-talk
Re: epicsThreadSleep and epicsThreadSleepQuantum Michael Davidsaver via Core-talk
Prev: RE: epicsThreadSleep and epicsThreadSleepQuantum Mark Rivers via Core-talk
Next: [Bug 608956] Re: vxWorks 6.8 deprecates the use of taskVarLib mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Re: epicsThreadSleep and epicsThreadSleepQuantum Konrad, Martin via Core-talk
ANJ, 16 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
