2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Strange behavior of async calcout with CPP input link
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
Date: Mon, 26 Aug 2019 21:13:39 +0000
Hi Ben,
On 8/26/19 12:42 PM, Michael Davidsaver via Core-talk wrote:
This might be https://bugs.launchpad.net/epics-base/+bug/1745039
Any chance you can try to reproduce with Base 7.0.3?
(2) if a record (here: DEV1:trgOn) is active (PACT=1) when an event
    arrives, it gets processed again, after completing.
This was only true when a record was processed directly by dbPutField()
(eg. via channel access).  "CPP" links use dbProcess(), which didn't do
this.
I concur with Michael. I think your use of a CPP link to trigger an asynchronous record is the source of the problem, and I believe that you would still see the problem even when running it on Base-7.0.3.
A CPP link adds its the record to the scanOnce queue to perform the processing. If the record happens to be busy (PACT=TRUE) when the onceTask() gets to it that trigger will be lost. To confirm, try setting DEV1:trgOn.TPRO and you should see something like
scanOnce: Active: DEV1:trgOn
instead of
scanOnce: Process: DEV1:trgOn
at the times when you end up with a seemingly impossible state.
If you were to change DEV1:st into a calcout record and make its OUT field "DEV1:trgOn.B PP" (removing the INPB field setting from DEV1:trgOn) this should enable the RPRO behaviour that you're looking for, although I'm not sure if it will fix the problem completely.
HTH,
- Andrew
On 8/26/19 9:46 AM, Benjamin Franksen via Core-talk wrote:
I am using base-3.15.6. This is a part of a larger database, running on
a soft IOC on Linux:
record(calc,"DEV1:st") {
    # the field details are irrelevant here,
    # just note this is a simple soft record
    # that gets processed via CPP input links
    field(INPA,"DEV1:stZ CPP")
    field(INPB,"DEV1:stS CPP")
    field(CALC,"A<<4|B&0xf")
record(calcout,"DEV1:trgOn") {
    field(INPA,"DEV1:sel")
    # trigger processing on change of readback
    field(INPB,"DEV1:st CPP")
    field(CALC,"A==B")
    field(DOPT,"Transition to non-zero")
    field(DTYP,"Async Soft Channel")
    field(OUT,"DEV2:switch CA")
The values involved are all integers.
DEV1:sel is the setpoint, DEV1:st is the (soft) readback, which gets
triggered by writing DEV1.sel via a chain of FLNKs, OUT PP links and CPP
input links. The idea is to write a "1" to the DEV2:switch (which is a
different device controlled by another IOC) when the readback has
settled to the same value as the setpoint. The device DEV1 is complex
and requires various separate commands to effect the change, and the
readback can go through 2 or 3 different values before finally
coinciding with the setpoint.
When I set DEV1:sel (using caput) to different values, I can sometimes
get into a situation where the database has the following (persistent)
state:
DEV1:sel.VAL=0
DEV1:st.VAL=0
DEV1:trgOn.A=0
DEV1:trgOn.B=8
DEV1:trgOn.VAL=0
I think this should not be possible, assuming that
(1) the value of the last monitor event (here: from DEV1:st) always wins
    over previous events, and
Either this is a bug or at least one of my assumptions is wrong. I
wonder which.
Cheers
Ben
Complexity comes for free, Simplicity you have to work for.
Re: Strange behavior of async calcout with CPP input link Benjamin Franksen via Core-talk
Re: Strange behavior of async calcout with CPP input link Michael Davidsaver via Core-talk
Prev: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Strange behavior of async calcout with CPP input link Michael Davidsaver via Core-talk
Next: Re: Strange behavior of async calcout with CPP input link Benjamin Franksen via Core-talk
ANJ, 27 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
