2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Strange behavior of async calcout with CPP input link
From: Benjamin Franksen via Core-talk <[email protected]>
Date: Tue, 27 Aug 2019 16:26:25 +0200
I'll answer both you replies in one message.
Am 26.08.19 um 23:13 schrieb Johnson, Andrew N. via Core-talk:
> On 8/26/19 12:42 PM, Michael Davidsaver via Core-talk wrote:
> This might be https://bugs.launchpad.net/epics-base/+bug/1745039
I think so.
> Any chance you can try to reproduce with Base 7.0.3?
Here is a small self-contained database to reproduce this:
record(calcout,"input") {
    field(CALC,"A<4?A+1:A")
    field(INPA,"input")
    field(ODLY,"1")
    field(OUT,"input.A CA")
record(calcout,"output") {
    field(DTYP,"Async Soft Channel")
    field(ODLY,"1.5")
    field(INPA,"input CPP")
    field(CALC,"A")
    field(TPRO,1)
record(calc,"check") {
    field(INPB,"output CPP")
    field(CALC,"A==B")
Processing "input" (caput input.PROC 1) starts the test. The "check"
record should eventually settle to 1.
With 7.0.3 I get this output:
scanOnce: dbProcess of 'output' # initial CPP processing
scanOnce: dbProcess of Active 'output' with RPRO=0
Note how this says "with RPRO=0".
And camonitor says:
franksen@tiber: ~ > camonitor input output check
input                          <undefined> 0 UDF INVALID
output                         2019-08-27 16:02:16.106413 0
check                          2019-08-27 16:02:16.106617 1
input                          2019-08-27 16:02:26.498483 1
check                          2019-08-27 16:02:26.498721 0
input                          2019-08-27 16:02:27.493734 2
output                         2019-08-27 16:02:27.993908 1
input                          2019-08-27 16:02:28.489068 3
input                          2019-08-27 16:02:29.484350 4
output                         2019-08-27 16:02:29.984458 3
So this happens with 7.0.3, too.
> (2) if a record (here: DEV1:trgOn) is active (PACT=1) when an event
> arrives, it gets processed again, after completing.
> This was only true when a record was processed directly by
> dbPutField() (eg. via channel access).  "CPP" links use dbProcess(),
> which didn't do this.
> I concur with Michael. I think your use of a CPP link to trigger an
> asynchronous record is the source of the problem, and I believe that
> you would still see the problem even when running it on Base-7.0.3.
Yes.
Thanks for your debugging hints and possible work-arounds. My concrete
problem has vanished in the meantime because I found that using "Async
Soft Channel" for DEV1:trgOn wasn't necessary. Indeed using the plain
"Soft Channel" fixed the problem.
I still think the difference in behavior between processing due to a CPP
input link versus processing due to a PP or CA output link is quite
surprising.
Attachment: signature.asc
Description: OpenPGP digital signature
Re: Strange behavior of async calcout with CPP input link Johnson, Andrew N. via Core-talk
Strange behavior of async calcout with CPP input link Benjamin Franksen via Core-talk
Re: Strange behavior of async calcout with CPP input link Michael Davidsaver via Core-talk
Prev: Build failed: epics-base base-iocsherr-284 AppVeyor via Core-talk
Next: [Bug 1841608] [NEW] logClient falsely sends error logs on all connections Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Strange behavior of async calcout with CPP input link Johnson, Andrew N. via Core-talk
Next: Re: Strange behavior of async calcout with CPP input link Johnson, Andrew N. via Core-talk
ANJ, 27 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
