2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to resolve git merge conflict in submodules?
From: Jeong Han Lee via Core-talk <[email protected]>
To: [email protected], "Zimoch Dirk (PSI)" <[email protected]>
Date: Fri, 20 Sep 2019 15:00:41 +0200
Hi Dirk,
If you run the following command, you can access the diff info from main epics-base into submodules
  git config --global diff.submodule diff
  This is the corresponding option for ~/.gitconfig
  [diff]
	submodule=diff
  I don't know which version of git will support this feature.
If you work into git submodules, go there, change it, and commit to git submodule repo individually. And move back to the main, and change "hash id" of this submodule, and commit to main repo.
Sometime, if you don't care about, you can use ignore option, in your main repo also such as.
[submodule "epics-base"]
        path = epics-base
        url = https://github.com/epics-base/epics-base
        branch = 7.0
        ignore = all
  HTH,
  Han
On 9/20/19 2:40 PM, Marty Kraimer via Core-talk wrote:
Have you tried git diff?
For example:
git diff  modules/pvData
Marty
On 9/20/19 4:10 AM, Zimoch Dirk (PSI) via Core-talk wrote:
On Fri, 2019-09-20 at 08:07 +0000, Zimoch Dirk (PSI) via Core-talk wrote:
Hi all,
I have a git problem (again) and google and stackoverflow did not really help.
A merge failed with this status:
I wasn't in the top directory but in modules/. Here is the git status from top.
# Changes to be committed:
#    modified:   configure/CONFIG_BASE_VERSION
#    modified:   documentation/RELEASE_NOTES.html
#    modified:   documentation/ReleaseChecklist.html
#    modified:   modules/ca/configure/CONFIG_CA_VERSION
#    modified:   modules/database/configure/CONFIG_DATABASE_VERSION
#    modified:   modules/database/src/ioc/misc/dbCore.dbd
#    modified:   modules/libcom/configure/CONFIG_LIBCOM_VERSION
#    modified:   modules/libcom/src/log/iocLog.c
#    modified:   modules/libcom/src/log/iocLogServer.c
#    modified:   modules/libcom/src/log/logClient.c
#    modified:   modules/libcom/src/log/logClient.h
#    modified:   modules/libcom/src/osi/os/RTEMS/devLibVMEOSD.c
#    modified:   modules/normativeTypes
#    modified:   modules/pva2pva
#    modified:   modules/pvaClient
# Unmerged paths:
#   (use "git add <file>..." to mark resolution)
#    both modified:      modules/pvAccess
#    both modified:      modules/pvData
#    both modified:      modules/pvDatabase
# Changes not staged for commit:
#   (use "git add <file>..." to update what will be committed)
#   (use "git checkout -- <file>..." to discard changes in working directory)
#    modified:   modules/normativeTypes (new commits)
#    modified:   modules/pva2pva (new commits)
#    modified:   modules/pvaClient (new commits)
What can I do about pvAccess, pvData, and pvDatabase? I cannot even find out what the conflict is.
Dirk
Re: How to resolve git merge conflict in submodules? Zimoch Dirk (PSI) via Core-talk
Re: How to resolve git merge conflict in submodules? Marty Kraimer via Core-talk
Prev: Re: How to resolve git merge conflict in submodules? Marty Kraimer via Core-talk
Next: Re: EPICS 7 build failures on Appveyor/Windows Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: How to resolve git merge conflict in submodules? Zimoch Dirk (PSI) via Core-talk
ANJ, 20 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
