On Fri, 2019-09-20 at 15:00 +0200, Jeong Han Lee wrote:
> Hi Dirk,
> If you run the following command, you can access the diff info from
> main epics-base into submodules
> git config --global diff.submodule diff
> This is the corresponding option for ~/.gitconfig
> [diff]
> submodule=diff
> I don't know which version of git will support this feature.
Now I get this when I try git status:
warning: Unknown value for 'diff.submodule' config variable: 'diff'
git version 1.8.3.1
> If you work into git submodules, go there, change it, and commit to
> git submodule repo individually. And move back to the main, and change
> "hash id" of this submodule, and commit to main repo.
> Sometime, if you don't care about, you can use ignore option, in your
> main repo also such as.
> [submodule "epics-base"]
> path = epics-base
> url = https://github.com/epics-base/epics-base
> branch = 7.0
> ignore = all
> HTH,
> Han
> On 9/20/19 2:40 PM, Marty Kraimer via Core-talk wrote:
> > Have you tried git diff?
> > For example:
> > git diff modules/pvData
> > Marty
> > On 9/20/19 4:10 AM, Zimoch Dirk (PSI) via Core-talk wrote:
> > > On Fri, 2019-09-20 at 08:07 +0000, Zimoch Dirk (PSI) via Core-talk wrote:
> > > > Hi all,
> > > > I have a git problem (again) and google and stackoverflow did not
> > > > really help.
> > > > A merge failed with this status:
> > > I wasn't in the top directory but in modules/. Here is the git status
> > > from top.
> > > # Changes to be committed:
> > > # modified: configure/CONFIG_BASE_VERSION
> > > # modified: documentation/RELEASE_NOTES.html
> > > # modified: documentation/ReleaseChecklist.html
> > > # modified: modules/ca/configure/CONFIG_CA_VERSION
> > > # modified: modules/database/configure/CONFIG_DATABASE_VERSION
> > > # modified: modules/database/src/ioc/misc/dbCore.dbd
> > > # modified: modules/libcom/configure/CONFIG_LIBCOM_VERSION
> > > # modified: modules/libcom/src/log/iocLog.c
> > > # modified: modules/libcom/src/log/iocLogServer.c
> > > # modified: modules/libcom/src/log/logClient.c
> > > # modified: modules/libcom/src/log/logClient.h
> > > # modified: modules/libcom/src/osi/os/RTEMS/devLibVMEOSD.c
> > > # modified: modules/normativeTypes
> > > # modified: modules/pva2pva
> > > # modified: modules/pvaClient
> > > # Unmerged paths:
> > > # (use "git add <file>..." to mark resolution)
> > > # both modified: modules/pvAccess
> > > # both modified: modules/pvData
> > > # both modified: modules/pvDatabase
> > > # Changes not staged for commit:
> > > # (use "git add <file>..." to update what will be committed)
> > > # (use "git checkout -- <file>..." to discard changes in working
> > > directory)
> > > # modified: modules/normativeTypes (new commits)
> > > # modified: modules/pva2pva (new commits)
> > > # modified: modules/pvaClient (new commits)
> > > > What can I do about pvAccess, pvData, and pvDatabase? I cannot even
> > > > find out what the conflict is.
> > > > Dirk
- Re: How to resolve git merge conflict in submodules? Michael Davidsaver via Core-talk
- How to resolve git merge conflict in submodules? Zimoch Dirk (PSI) via Core-talk
- Re: How to resolve git merge conflict in submodules? Zimoch Dirk (PSI) via Core-talk
- Re: How to resolve git merge conflict in submodules? Marty Kraimer via Core-talk
- Re: How to resolve git merge conflict in submodules? Jeong Han Lee via Core-talk
<2019>
2025
2026
<2019>
2025
2026
