2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: Error message binding socket 5076 on vxWorks
From: Michael Davidsaver via Core-talk <[email protected]>
Date: Sun, 12 Jan 2020 09:50:49 -0800
On 1/12/20 9:19 AM, Mark Rivers wrote:
>> When combined with a lack of coordination within the implementations, each process with both a PVA client and server will always bind twice to 5076.
> Is that is what is causing the "Error binding" message?  What PVA client would they be running.  They are running the PVA server in base 7, including qsrv.
This is, and always has been, happening on all targets.
It should not be causing a problem if all sockets bound to 5076
set the SO_REUSEADDR (or sometimes SO_REUSEPORT) socket option.
This is 'epicsSocketEnableAddressUseForDatagramFanout()' in Base.
vxWorks currently uses the posix version.
https://github.com/epics-base/epics-base/blob/468f965dc2753e7a381dcc09dd9b5656e3149ac2/modules/libcom/src/osi/os/posix/osdSockAddrReuse.cpp#L42
While I would expect this would have been noticed before now,
one possibility is that SO_REUSEADDR doesn't have the desired effect
on vxWorks.  At least not for UDP sockets.
There is no test coverage, and CA has never needed it to work on this OS.
Re: Error message binding socket 5076 on vxWorks Michael Davidsaver via Core-talk
Error message binding socket 5076 on vxWorks Mark Rivers via Core-talk
Re: Error message binding socket 5076 on vxWorks Mark Rivers via Core-talk
Prev: Re: Error message binding socket 5076 on vxWorks Mark Rivers via Core-talk
Next: Re: Error message binding socket 5076 on vxWorks Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 12 Jan 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
