On Mon, May 25, 2020 at 2:27 PM Michael Davidsaver via Core-talk
<core-talk at aps.anl.gov> wrote:
> On 5/25/20 11:37 AM, Michael Davidsaver wrote:
> > A couple of things.
> And a couple of more.
> I notice that the only internal usage of _CORE_message_queue_Send() in RTEMS
> is in rtems_message_queue_send(), where it never blocks (wait=0). So this
> might be a bug in the wait=1 case.
> https://github.com/epicsdeb/rtems/blob/023ea6196c9f3975663328d00d5603ce040deb6c/cpukit/score/src/coremsgsubmit.c#L135-L167
I'll try to have a look from RTEMS perspective to see if this is a
latent bug. 4.10 is getting old to maintain but I've been trying to
keep it going (although, apparently, breaking some things too). This
code has been re-written in 4.11 and again for 5.0 for SMP, but I
don't see paths with wait = true in newer versions either, so it may
be untested code.
> As I look at epicsMessageQueueTest.cpp I don't see any test which
> deliberately times out.
> >> So far every time I have run this test the numSent counter has always come back as 420 instead of 500. The fastSender() code looks like this:
> I see something similar (RTEMS 4.9.6 w/ mvme3100 + QEMU), but not always 420
> > # sleepySender: sending every 0.009 seconds
> > ok 57 - Sent 500 (should be 500)
> > ok 58 - Received 500 (should be 500)
> > # sleepySender: sending every 0.010 seconds
> > ok 59 - Sent 500 (should be 500)
> > ok 60 - Received 500 (should be 500)
> > # sleepySender: sending every 0.011 seconds
> > ok 61 - Sent 500 (should be 500)
> > ok 62 - Received 500 (should be 500)
> > # sleepyReceiver: acquiring every 0.009 seconds
> > not ok 63 - Sent 421 (should be 500)
> > ok 64 - Received 500 (should be 500)
> > # sleepyReceiver: acquiring every 0.010 seconds
> > not ok 65 - Sent 418 (should be 500)
> > ok 66 - Received 500 (should be 500)
> > # sleepyReceiver: acquiring every 0.011 seconds
> > not ok 67 - Sent 418 (should be 500)
> > ok 68 - Received 500 (should be 500)
- Re: RTEMS/osdMessageQueue.c Gedare Bloom via Core-talk
- RTEMS/osdMessageQueue.c Johnson, Andrew N. via Core-talk
- Re: RTEMS/osdMessageQueue.c Michael Davidsaver via Core-talk
<2020>
2025
2026
<2020>
2025
2026
